What AutoSupport is
The AutoSupport feature enables SnapManager server to send AutoSupport messages to the storage system after the backup operation is complete.
SnapManager sends AutoSupport messages only for the successful backup operations. |
You can enable or disable AutoSupport by assigning the following values to the auto_support.on configuration parameter in the smo.config configuration file:
TRUE - Enables AutoSupport
FALSE - Disables AutoSupport
By default, AutoSupport is enabled in SnapManager. |
Related information
