SnapManager Oracle
The smo clone detach command
After splitting a cloned volume from its parent volume in Data ONTAP, you can run the clone detach command from SnapManager to let SnapManager know that the volume is no longer a clone.
Syntax
smo clone detach -profile profile_name -label clone_label
  • -profile profile_name
    Specifies the profile name from which the clone is created.
  • -label clone_label
    Specifies the name generated by the clone operation.
Example
The following command detaches the clone:
smo clone detach -profile SALES1 -label sales1_clone
