SnapManager Oracle
The smo clone split-delete command
This command lets you delete a clone split operation cycle entry from a repository database.
Syntax
-profile profile \[-host hostname\]
\[-label split-label \| -id split-id\]
\[-quiet \| -verbose\]
  • -profile profile
    Specifies the profile name of the clone.
  • -host hostname
    Specifies the hostname in which the clone exists.
  • -label split-label
    Specifies the label name generated by clone split start process.
  • -id split-id
    Specifies the unique ID generated by clone split start process.
  • -quiet
    Displays only error messages on the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages on the console.
