The smo clone split-result command
Syntax
This command lets you view the result of the clone split process.
smo clone split-result -profile profile \[-host hostname\] \[-label split-label \| -id split-id\] \[-quiet \| -verbose\]
-profile profile
Specifies the profile name of the clone.
-host hostname
Specifies the hostname in which the clone exists.
-label split-label
Specifies label name generated by clone split start process.
-id split-id
Specifies unique ID generated by clone split start process.
-quiet
Displays only error messages on the console. The default is to display error and warning messages.
-verbose
Displays error, warning, and informational messages on the console.
