SnapManager Oracle
The smo repository rollback command
This command enables you to rollback or revert from a higher version of SnapManager to the original version from which you upgraded.
Syntax
-repository
-dbname repo_service_name
-host repo_host
-login -username repo_username
-port repo_port
-rollbackhost host_with_target_database
[-force]
\[-quiet \| -verbose\]
  • -repository
    The options that follow -repository specify the details of the database for the repository.
  • -dbname repo_service_name
    Specifies the name of the database that stores the repository. Use either the global name or the SID.
  • -host repo_host
    Specifies the name or IP address of the host computer the repository database runs on.
  • -login
    Starts the repository login details.
  • -username repo_username
    Specifies the user name needed to access the database that stores the repository.
  • -rollbackhost host_with_target_database
    Specifies the name of the host which will be rolled back from a higher version of SnapManager to the original lower version.
  • -port repo_port
    Specifies the TCP port number used to access the database that stores the repository.
  • -force
    Attempts to force the update of the repository. SnapManager prompts you to make a backup of the current repository before updating.
  • -noprompt
    Does not display the prompt before updating the repository database. Using the -noprompt option ensures the prompt does not appear, making it easier to update repositories using a script.
  • -quiet
    Displays only error messages on the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages on the console.
Example command
The following example updates the repository in the SALESDB database.
smo repository rollback -repository -dbname SALESDB
-host server1 -login -username admin -port 1521 -rollbackhost hostA
