SnapManager Oracle
The smo backup unmount command
You can run the backup unmount command to unmount a backup.
Syntax
        smo backup unmount
-profile profile_name
[-label label \[-data \| -archivelogs\] \| \[-id id\]
\[-force\]
\[-dump\]
\[-quiet \| -verbose\]
  • -profile profile_name
    Specifies the profile for which you want to unmount a backup. The profile contains the identifier of the database and other database information.
  • -id id
    Unmounts the backup with the specified GUID. The GUID is generated by SnapManager when you create a backup. You can use the smo backup list command to display the GUID for each backup.
  • -label label
    Unmounts the backup with the specified label.
  • -data
    Specifies the data files.
  • -archivelogs
    Specifies the archive log files.
  • -dump
    Collects the dump files after a successful or failed unmount operation.
  • -force
    Unmounts the backup even if there are problems in freeing the resources associated with the backup. SnapManager tries to unmount the backup and clean up any associated resources. The log shows the unmount operation as successful, but you may have to manually clean up resources if there are errors in the log.
  • -quiet
    Displays only error messages in the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages in the console.
Example
The following is an example of an unmount operation:
# smo backup unmount -label test -profile SALES1 -verbose
SMO-13046 [INFO ]: Operation GUID 8abc013111b909eb0111b90a02f50001 starting on Profile SALES1
SMO-08028 [INFO ]: Beginning to disconnect connected mount(s)
[/u/user1/mnt/_mnt_ssys1_logs_SMO_SALES1_hsdb1_F_C_1_8abc013111a450480111a45066210001,
 /u/user1/mnt/_mnt_ssys1_data_SMO_SALES1_hsdb1_F_C_1_8abc013111a450480111a45066210001].
SMO-08030 [INFO ]: Done disconnecting connected mount(s)
SMO-13037 [INFO ]: Successfully completed operation: Backup Unmount
SMO-13048 [INFO ]: Operation Status: SUCCESS
SMO-13049 [INFO ]: Elapsed Time: 0:00:33.715
Operation Id [8abc013111b909eb0111b90a02f50001] succeeded.
Related information
