SnapManager Oracle
The smo credential clear command
This command clears the cache of the user credentials for all secured resources.
Syntax
\[-quiet \| -verbose\]
  • -quiet
    Displays only error messages on the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages on the console.
Example command
This example clears all of the credentials for the user running the command.
smo credential clear -verbose
SMO-20024 [INFO ]: Cleared credentials for user "user1".
Related information
