The smo help command
You can run the help command to display information about the SnapManager commands and their options. If you do not supply a command name, it displays a list of valid commands. If you supply a command name, it displays the syntax for that command.
Syntax
smo help \[backup\|cmdfile\|clone\|credential\|help\|operation\|profile\|protection-policy\|repository\|system\|version\|plugin\|diag\|history\|schedule\|notification\|storage\|get\] \[-quiet \| -verbose\]
The following are some command names you can use with this command:
backup
clone
cmdfile
credential
diag
get
notification
help
history
operation
plugin
profile
protection policy
repository
schedule
storage
system
version
