SnapManager Oracle
The smo operation dump command
You can run the operation dump command to create a JAR file that contains diagnostic information about an operation.
Syntax
        smo operation dump
-profile profile_name
\[-label label_name \| -id guid\]
\[-quiet \| -verbose\]
  • -profile profile_name
    Specifies the profile for which you want to create the dump files. The profile contains the identifier of the database and other database information.
  • -label label_name
    Creates dump files for the operation and assigns the specified label.
  • -id guid
    Creates dump files for the operation with the specified GUID. The GUID is generated by SnapManager when the operation begins.
  • -quiet
    Displays only error messages in the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages in the console.
Example
The following example creates the dump file for the backup:
smo operation dump -profile SALES1
-id 8abc01ec0e78f3e2010e78f3fdd00001
Dump file created Path:/userhomedirectory/.netapp/smo/3.3/smo_dump_8abc01ec0e78f3e2010e78f3fdd00001.jar
Related information
