SnapManager Oracle
The smo profile verify command
You can run the profile verify command to verify the profile set up. You must mount the database before running this command.
Syntax
        smo profile verify
-profile profile_name
\[-quiet \| -verbose\]
  • -profile
    Specifies the profile to verify. The profile contains the identifier of the database and other database information.
  • -quiet
    Displays only error messages in the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages in the console.
Example
The following example verifies the profile:
smo profile verify -profile test_profile  -verbose
[ INFO] SMO-07431: Saving starting state of the database: racb1(OPEN).
[ INFO] SMO-07431: Saving starting state of the database: racb2(SHUTDOWN), racb1(OPEN).
[ INFO] SD-00019: Discovering storage resources for all system devices.
[ INFO] SD-00020: Finished storage discovery for all system devices.
[ INFO] SMO-05070: Database profile test_profile is eligible for fast restore.
[ INFO] SMO-07433: Returning the database to its initial state: racb2(SHUTDOWN), racb1(OPEN).
[ INFO] SMO-13048: Profile Verify Operation Status: SUCCESS
[ INFO] SMO-13049: Elapsed Time: 0:04:14.919
Operation Id [Nfffde14ac88cd1a21597c37e8d21fe90] succeeded.
Related information
