SnapManager Oracle
The smo repository create command
Syntax
This command creates a repository in which to store database profiles and associated credentials. This command also checks to see that the block size is adequate.
-repository
-port repo_port
-dbname repo_service_name
-host repo_host
-login -username repo_username
[-force] [-noprompt]
\[-quiet \| -verbose\]
  • -repository
    The options that follow -repository specify the details of the database for the repository
  • -port repo_port
    Specifies the TCP port number used to access the database that stores the repository.
  • -dbname repo_service_name
    Specifies the name of the database that stores the repository. Use either the global name or the SID.
  • -host repo_host
    Specifies the name or IP address of the host computer the repository database runs on.
  • -login
    Starts the repository login details.
  • -username repo_username
    Specifies the user name needed to access the database that stores the repository.
  • -force
    Attempts to force the creation of the repository. Using this option results in SnapManager prompting you to backup the repository before creating the repository.
  • -noprompt
    Does not display the prompt to backup the repository before creating it if you use the -force option. Using the -noprompt option ensures the prompt does not appear, making it easier to create repositories using a script.
  • -quiet
    Displays only error messages on the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages on the console.
Command example
The following example creates a repository in the database SMOREPO on the host hotspur.
smo repository create -repository -port 1521 -dbname SMOREPO -host hotspur -login -username grabal21 -verbose
SMO-09202 [INFO ]: Creating new schema as grabal21 on jdbc:oracle:thin:@//hotspur:1521/SMOREPO.
SMO-09205 [INFO ]: Schema generation complete.
SMO-09209 [INFO ]: Performing repository version INSERT.
SMO-09210 [INFO ]: Repository created with version: 30
SMO-13037 [INFO ]: Successfully completed operation: Repository Create
SMO-13049 [INFO ]: Elapsed Time: 0:00:08.844
