SnapManager Oracle
The smo system dump command
You can run the system dump command to create a JAR file that contains diagnostic information about the server environment.
Syntax
        smo system dump
\[-quiet \| -verbose\]
  • -quiet
    Displays only error messages in the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages in the console.
Example of the system dump command
The following example uses the smo system dump command to create a JAR file:
smo system dump
Path:/userhomedirectory/.netapp/smo/3.3.0/smo_dump_hostname.jar
