SnapManager Oracle
The smo system verify command
This command confirms that all the components of the environment required to run SnapManager are set up correctly.
Syntax
        smo system verify
\[-quiet \| -verbose\]
  • -quiet
    Displays only error messages on the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages on the console.
Example of the system verify command
The following example uses the smo system verify command.
smo system verify
SMO-13505 [INFO ]: Snapdrive verify passed.
SMO-13037 [INFO ]: Successfully completed operation: System Verify
SMO-13049 [INFO ]: Elapsed Time: 0:00:00.559
Operation Id [N4f4e910004b36cfecee74c710de02e44] succeeded.
