Where to go for more information
You can find information about the basic tasks involved in installing and using SnapManager.
| Document | Description |
SnapManager description page |
This page provides information about SnapManager, pointers to online documentation, and a link to the SnapManager download page, from which you can download the software. |
Data ONTAP SAN Configuration Guide for 7-Mode |
This document is available at mysupport.netapp.com. It is a dynamic, online document that contains the most up-to-date information about the requirements for setting up a system in a SAN environment. It provides the current details about storage systems and host platforms, cabling issues, switch issues, and configurations. |
SnapManager and SnapDrive Compatibility Matrix |
This document is available in the Interoperability section at mysupport.netapp.com/matrix. It is a dynamic, online document that contains the most up-to-date information specific to SnapManager and its platform requirements. |
SnapManager Release Notes |
This document comes with SnapManager. You can also download a copy from mysupport.netapp.com. It contains any last-minute information that you need to get the configuration up and running smoothly. |
NetApp host attach and support kits documentation |
System Configuration Guide |
Data ONTAP Block Access Management Guide |
Host operating system and database information |
These documents provide information about your host operating system and database software. |
