SnapManager Oracle
Storing encrypted passwords for custom scripts
By default, SnapManager does not store host credentials in the user credentials cache. However, you can change this. You can edit the smo.config file to allow storing of host credentials.
The smo.config file is located at <default installation location>/properties/smo.config
  1. Edit the smo.config file.
  2. Set host.credentials.persist to true.
