• Installation and Setup for UNIX for Clustered Data ONTAP
    • Product overview
    • Prepare for deployment
    • Configure databases
    • Install SnapManager
    • Set up SnapManager
    • Preparing storage systems for SnapMirror and SnapVault replication
    • Backing up and verifying your databases
    • Upgrading SnapManager
      • Post-upgrade tasks
      • Upgrading SnapManager hosts by using rolling upgrade
        • What a rollback is
  • Installation and Setup for UNIX for 7-mode
    • Product overview
  • Administration for UNIX
    • Product overview
      • Recommended general database layouts and storage configurations
      • Limitations when working with SnapManager
        • Limitations related to Oracle Database
    • Configuring SnapManager
      • SnapManager configuration parameters
    • Security and credential management
      • About role-based access control
      • Clear user credentials for all hosts, repositories, and profiles
      • Delete credentials for individual resources
    • Managing profiles for efficient backups
    • Backing up databases
      • What full and partial backups are
      • Create database backups
      • What AutoSupport is
      • Change the backup retention policy
    • Scheduling database backups
    • Restoring database backups
      • What database restore is
        • Guidelines for when you can use fast restore
      • Restore files from an alternate location
        • Restore backups from an alternate location overview
    • Cloning database backup
      • Create clone specifications
      • Considerations for cloning a database to an alternate host
      • Splitting a clone
    • Introduction to data protection in SnapManager
      • Configuring and enabling policy-driven data protection
      • Considerations for performing data protection
      • Restoring protected backups from secondary storage
    • SnapManager for SAP uses Protection Manager to protect a database backup
      • Protected backup configuration and execution
      • Database restore from backup
    • Performing management operations
    • Configuring an email notification
      • Configure email notification for a new profile
      • Configure email notification for an existing profile
    • Creating task specification file and scripts for SnapManager operations
      • Create pretask, post-task, and policy scripts
    • Updating storage system name and target database host name associated with a profile
    • Maintaining history of SnapManager operations
    • Using BR*Tools with SnapManager for SAP
    • SnapManager for SAP command reference
    • Troubleshooting SnapManager
      • Dump files
  • Installation and Administration for Windows
    • What SnapManagerfor SAP is
      • Advantages of using SnapManager
      • What the SnapManager for SAP architecture is
    • SnapManager for SAP deployment considerations
      • Requirements for running SnapManager
      • Database version support and configuration overview
    • Installing SnapManager for SAP
      • Preparing to install SnapManager for SAP
    • Start SnapManagerfor SAP
      • Accessing SnapManager
        • Start the SnapManager host server
      • Verify the environment
      • Create repositories
      • Protecting database backups by using postscripts
        • Create or update the post scripts
          • Create post-process, task-specification files
      • Dump files
