SnapManager limitations for clustered Data ONTAP
You must know the limitations for some functionalities and SnapManager operations if you are using clustered Data ONTAP.
The following functionalities are not supported if you are using SnapManager on clustered Data ONTAP:
Data protection capabilities if SnapManager is integrated with OnCommand Unified Manager
A database in which one LUN belongs to a system running Data ONTAP operating in 7-Mode and the other LUN belongs to a system running clustered Data ONTAP
SnapManager for SAP does not support migration of a Vserver, which is not supported by clustered Data ONTAP
SnapManager for SAP does not support the clustered Data ONTAP 8.2.1 functionality to specify different export policies for volumes and qtrees
