SnapManager configuration parameters
SnapManager provides a list of configuration parameters that you can edit depending on your requirement. The configuration parameters are stored in the smsap.config file. However, the smsap.config file might not contain all the supported configuration parameters. You can add the configuration parameters, depending on your requirement.
The following table lists all the supported SnapManager configuration parameters and also explains when to use these parameters:
| Parameters | Description | ||||
These parameters set the retention policy when you create a profile. For example, you can assign the following values:
This parameter defines how SnapManager can access data on secondary storage when it cannot be restored directly by using Protection Manager. The different ways to access the data on secondary storage are as follows:
This parameter assigns a name to the temporary volume. When SnapManager uses the indirect method for restoring data from secondary storage, it requires a scratch volume on the primary storage to hold a temporary copy of data until it is copied into the database files and the database is recovered. There is no default value. If you do not specify a value, you must enter a name in the restore command that uses the indirect method. For example, you can assign the following values:
This parameter allows SnapManager to free backups when they expire and when a fast restore is performed, even if data protection is not configured. This parameter frees the protected backups that expire and deletes the unprotected backups that expire. The possible values that you can assign are as follows:
This parameter allows SnapManager to store host credentials. By default, the host credentials are not stored. However, host credentials need to be stored if you have a custom script that runs on a remote clone and requires access to a remote server.You can enable storing of host credentials by assigning true to |
This parameter enables you to define the maximum number of files to be displayed in the restore preview.By default, SnapManager displays a maximum of 20 files in the restore preview. However, you can change to a value greater than 0. For example, you can assign the following value:
This parameter enables you to define the time in minutes for which SnapManager must wait for the
For any SnapManager operation, if the snap list command execution time exceeds the value assigned to |
This pruning parameter enables you to define the destination of the archive logs files. The archive log files are stored in multiple destinations. While pruning archive log files, SnapManager needs to know the destination of the archive log files. The possible values that you can assign are as follows:
This pruning parameter enables you to prune the archive log files backed up from the specified archive log destinations or backed up from external archive log destinations. The possible values that you can assign are as follows:
This pruning parameter enables you to define the maximum number of archive log files that you can prune at a given time. For example, you can assign the following value:
This parameter allows SnapManager to free the duplicate archive log backups if you assign |
This parameter enables you to specify the suffix that you want to add to differentiate the label names of the data backup and the archive log backup. For example, when you assign |
This parameter allows SnapManager to include the missing archive log files in the backup. The archive log files that do not exist in the active file system are not included in the backup. If you want to include all of the archive log files, even those that do not exist in the active file system, you must assign You can assign |
This parameter enables you to define the timeout value for the
When SnapManager takes more time to execute the |
This parameter allows SnapManager to perform the restore operation with Snapshot copies that were created before migrating from Data ONTAP operating in 7-Mode to clustered Data ONTAP.The default value assigned to the parameter is |
This parameter disables cleanup upon failure of long-running operations. You can set |
These parameters activate the sleep mechanism in the Direct NFS (dNFS) layout. After you create the backup of control files using dNFS or a Network File System (NFS), SnapManager tries to read the control files, but the files might not be found. To enable the sleep mechanism, ensure that When you enable the sleep mechanism, you must assign the sleep time to For example:
When you do not specify the backup label, SnapManager creates a default backup label. These SnapManager parameters allows you to customize the default backup label. To enable customization of the backup label, ensure that the value of To assign the new pattern of the backup label, you can assign keywords such as database name, profile name, scope, mode, and host name to
Oracle supports usage of the underscore in clone SID from Oracle 11gR2. This SnapManager parameter enables you to include an underscore in the clone SID name. To include an underscore in the clone SID name, ensure that the value of If you are using an Oracle version earlier than Oracle 11gR2 or if you do not want to include an underscore in the clone SID name, set the value to |
This parameter enables you to specify all the Oracle parameters that have comma (,) as the value.While performing any operation SnapManager uses For example, if the value of |
These parameters allow SnapManager to exclude the archive log files from the profiles and backups if the database is not on a Snapshot copy-enabled storage system and you want to perform SnapManager operations on that storage system.
The values assigned to these parameters can either be a top-level directory or a mount point where the archive log files are present or a subdirectory. If a top-level directory or a mount point is specified and if data protection is enabled for a profile on the host, then that mount point or directory is not included in the dataset that is created in Protection Manager. When there are multiple archive log files to be excluded from the host, you must separate the archive log file paths by using commas. To exclude archive log files from being included in the profile and being backed up, you must include one of the following parameters:
