Snapshots and Snapshot Schedules
Learn about viewing information about snapshots and snapshot schedules:
Snapshots
From the Volumes page that is available from the side panel for a selected cluster, you can view information about volume snapshots.
Select Volumes > Snapshots.
Alternatively, select Volumes > Active Volumes and in the Actions column, select the
icon for the volume you want and select View Snapshots.
(Optional) You can export the snapshot list as a CSV file by selecting the
icon.
The following list describes the available details:
| Heading | Description |
ID |
Displays the snapshot ID assigned to the snapshot. |
Volume ID |
ID given when the volume was created. |
Account ID |
ID of the account assigned to the volume. |
UUID |
Universally unique identifier. |
Size |
User-defined size of the snapshot. |
Volume Size |
Size of the volume from which the snapshot was created. |
Create Time |
The time at which the snapshot was created. |
Retain Until |
The day and time the snapshot will be deleted. |
Group Snapshot ID |
The group ID the snapshot belongs to if grouped together with other volume snapshots. |
Replicated |
Displays the status of the snapshot on the remote cluster:
Snapshot Schedules
From the Volumes > Snapshot Schedules page that is available from the side panel for a selected cluster, you can view snapshot schedule details.
You can export the snapshot schedule list as a CSV file by selecting the icon.
ID |
The schedule ID assigned to the schedule. |
Name |
User-assigned name of the schedule. |
Frequency |
The frequency at which the schedule is run. The frequency can be set in hours and minutes, weeks, or months. |
Recurring |
Indicates whether or not the schedule is recurring. |
Volume IDs |
The volume IDs included in the scheduled snapshot. |
Last Run |
The last time the schedule executed. |
Last Run Status |
The outcome of the last schedule execution.
Possible values: |
Manually Paused |
Identifies whether or not the schedule has been manually paused. |
