View SolidFire storage node details
Each node is a collection of SSDs. Each storage node comes with CPU, networking, cache, and storage resources. The storage node resources are pooled into a cluster of nodes.
On the Nodes page, the information bar provides a quick overview of the following data:
MVIP: Management virtual IP address
MVIP VLAN ID: Virtual LAN ID for the MVIP
SVIP: Storage virtual IP address
SVIP VLAN ID: Virtual LAN ID for the SVIP
View information about storage nodes
The following information is available for each storage node in the cluster:
| Heading | Description |
ID |
System-generated ID for the node. |
Status |
The status of the node:
Name |
The system-generated node name. |
Type |
Displays the model type of the node. |
Version |
Version of Element software running on each node. |
Service Tag |
Unique service tag number assigned to the node. |
Serial Number |
Unique serial number assigned to the node. |
Management IP |
Management IP address assigned to node for 1GbE or 10GbE network admin tasks. |
Cluster IP |
Cluster IP address assigned to the node used for the communication between nodes in the same cluster. |
Storage IP |
Storage IP address assigned to the node used for iSCSI network discovery and all data network traffic. |
Replication Port |
The port used on nodes for remote replication. |
Role |
Identifies what role the node has in the cluster:
Average IOPS Last 30 mins |
Sum of the average number of IOPS executed in the last 30 minutes against all volumes that have this node as their primary. |
Average Throughput Last 30 mins |
Sum of average throughputs executed in the last 30 minutes against all volumes that have this node as their primary. |
Average Latency (µs) Last 30 mins |
The average time in microseconds, as measured over the last 30 minutes, to complete read and write operations to all volumes that have this node as their primary. To report this metric based on active volumes, only non-zero latency values are used. |
