Create an Azure NetApp Files system in the NetApp Console
After you set up a Microsoft Entra application and add the credentials to the NetApp Console, create an Azure NetApp Files system so that you can start creating the volumes that you need.
Steps
From the Systems page, select Add system.
Select Microsoft Azure.
Next to Azure NetApp Files, select Discover.
On the Details page, enter a system name and select the credentials that you previously set up.
Select Continue.
Result
You now have an Azure NetApp Files system.
What's next?
