Cloud Volumes ONTAP
Azure
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Manage capacity-based licensing for Cloud Volumes ONTAP
Contributors netapp-manini netapp-shwetav
Manage your capacity-based licenses from the NetApp Console to ensure that your NetApp account has enough capacity for your Cloud Volumes ONTAP systems.
Capacity-based licenses enable you to pay for Cloud Volumes ONTAP per TiB of capacity.
You can manage capacity-based Cloud Volumes ONTAP licenses from the NetApp Console.
Note While the actual usage and metering for the products and services managed in the Console are always calculated in GiB and TiB, the terms GB/GiB and TB/TiB are used interchangeably. This is reflected in the Cloud Marketplace listings, price quotes, listing descriptions, and in other supporting documentation
How licenses are added to NetApp Console
After you purchase a license from your NetApp sales representative, NetApp will send you an email with the serial number and additional licensing details.
In the meantime, the Console automatically queries NetApp's licensing service to obtain details about the licenses associated with your NetApp Support Site account. If there are no errors, it adds the licenses.
If the Console can't add the license, you'll need to manually add them. For example, if the Console agent is installed at a location that doesn't have internet access, you'll need to add the licenses yourself. Learn how to add purchased licenses to your account.
View the consumed capacity in your account
The Console shows you the total consumed capacity in your account and the consumed capacity by licensing package. This can help you understand how you're being charged and whether you need to purchase additional capacity.
Steps
  1. From the left navigation pane, select Administration > Licenses and subscriptions.
  2. On the Overview tab, the Cloud Volumes ONTAP tile displays the current capacity provisioned for your account.
    screenshot cvo licensing card
    • Direct license is the total provisioned capacity of all Cloud Volumes ONTAP systems in your NetApp account. The charging is based on each volume's provisioned size, regardless of local, used, stored, or effective space within the volume.
    • Annual contract is the total licensed capacity (bring your own license (BYOL) or Marketplace Contract) that you purchased from NetApp.
    • PAYGO is the total provisioned capacity using cloud marketplace subscriptions. Charging via PAYGO is used only if the consumed capacity is higher than the licensed capacity or if there is no BYOL license available in the Console.
  3. Select View to see the consumed capacity for each of your licensing packages.
  4. Select the Licenses tab to see details for each package license that you have purchased.
    To better understand the capacities that display for the Essentials package, you should be familiar with how charging works. Learn about charging for the Essentials package.
  5. Select the Subscriptions tab to see the consumed capacity by license consumption model. This tab includes both PAYGO and annual contract licenses.
    You'll only see the subscriptions that are associated with the organization that you are that you're currently viewing.
  6. As you view the information about your subscriptions, you can interact with the details in the table. Expand a row to view more details.
    • Select the plus icon at the end of the table header to choose which columns appear in the table.
      Note that the Term and Auto Renew columns don't appear by default. The Auto Renew column displays renewal information for Azure contracts only.
Viewing package details
You can view details about the capacity used per package by switching to legacy mode on the Cloud Volumes ONTAP page.
  3. Select View to see the provisioned capacity for each of your licensing packages.
  4. Select Switch to advanced view.
    A screenshot of the Switch to advanced view button
  5. View the details of the package you want to see.
    A screenshot of switch to standard view button
Change charging methods
Capacity-based licensing is available in the form of a package. When you create a Cloud Volumes ONTAP system, you can choose from several licensing packages based on your business needs. If your needs change after you create the system, you can change the package at any time. For example, you might change from the Essentials package to the Professional package.
About this task
  • Changing the charging method doesn't affect whether you're charged through a license purchased from NetApp (BYOL) or from your cloud provider's marketplace pay-as-you-go (PAYGO) subscription.
    The Console always attempts to charge against a license first. If a license isn't available, it charges against a marketplace subscription. You don't have to convert a BYOL subscription to marketplace subscription or vice versa.
  • If you have a private offer or contract from your cloud provider's marketplace, changing to a charging method that's not included in your contract will result in charging against BYOL (if you purchased a license from NetApp) or PAYGO.
  • If you plan to bill Cloud Volumes ONTAP capacity through the standalone Cloud Volumes ONTAP subscription in AWS marketplace, the Cloud Volumes ONTAP system must use a supported capacity-based package (Essentials or Freemium). The Professional package is not supported for the standalone listing and continues to bill through the NIS subscription. After selecting the package you want, use Billing preferences in NetApp Console to choose the marketplace subscription used for Cloud Volumes ONTAP billing.
Steps
  2. Select the Overview tab.
  3. On the Cloud Volumes ONTAP tile, select View.
    A screenshot of the Switch to Legacy view button
  5. Scroll down to the Capacity-based license table and select Change charging method.
    A screenshot of the Cloud Volumes ONTAP page in the Console where the Change charging method button is just above the table.
  6. On the Change charging method pop-up, select a Cloud Volumes ONTAP system, choose the new charging method, and then confirm your understanding that changing the package type will affect service charges.
  7. Select Change charging method.
Download usage reports
You can download four usage reports from the Console. These usage reports provide capacity details of your subscriptions and tell you how you're being charged for the resources in your Cloud Volumes ONTAP subscriptions. The downloadable reports capture data at a point in time and can be easily shared with others.
Screenshot shows the Cloud Volumes ONTAP capacity based licenses page and highlights the usage report button.
The following reports are available for download. Capacity values shown are in TiB.
  • High-level usage: This report summarizes the total capacity consumed across your account and breaks it down by billing method (pre-committed licenses versus pay-as-you-go). It includes the following information:
    Column Description
    Total consumed capacity
    The total provisioned capacity across all Cloud Volumes ONTAP systems in your account.
    Total precommitted capacity
    The total licensed capacity that you purchased from NetApp, including both BYOL licenses and Marketplace contracts. This value is the sum of Total BYOL capacity and Total Marketplace contracts capacity.
    Total BYOL capacity
    The portion of pre-committed capacity covered by bring your own license (BYOL) licenses that you purchased directly from NetApp.
    The portion of pre-committed capacity covered by annual marketplace contracts or private offers purchased through your cloud provider's marketplace.
    Total PAYGO capacity
    The portion of consumed capacity that isn't covered by any pre-committed license and is billed at pay-as-you-go (PAYGO) hourly marketplace rates.
  • Cloud Volumes ONTAP package usage: This report provides the same capacity breakdown as the High-level usage report, but organized per licensing package. It includes the following information:
    Column Description
    The total provisioned capacity for this package across all Cloud Volumes ONTAP systems in your account.
    The total licensed capacity for this package that you purchased from NetApp, including both BYOL licenses and Marketplace contracts. This value is the sum of Total BYOL capacity and Total Marketplace contracts capacity.
    Total BYOL capacity
    The portion of pre-committed capacity for this package covered by bring your own license (BYOL) licenses that you purchased directly from NetApp.
    The portion of pre-committed capacity for this package covered by annual marketplace contracts or private offers purchased through your cloud provider's marketplace.
    The portion of consumed capacity for this package that isn't covered by any pre-committed license and is billed at pay-as-you-go (PAYGO) hourly marketplace rates.
  • Storage VMs usage: This report shows how charged capacity is broken down across Cloud Volumes ONTAP systems and storage virtual machines (SVMs). This information is only available in the report. It contains the following information:
    Column Description
    System ID and name
    The unique identifier (UUID) and display name of the Cloud Volumes ONTAP system.
    Cloud
    The cloud provider where the system is deployed (for example, AWS, Azure, or Google Cloud).
    NetApp account ID
    The identifier for the NetApp account associated with the system.
    System configuration
    The deployment configuration of the system (for example, single node or HA pair).
    SVM name
    The name of the storage virtual machine (SVM) within the Cloud Volumes ONTAP system.
    Provisioned capacity
    The total capacity provisioned on the SVM.
    Charged capacity roundup
    The capacity actually billed for the SVM. Each SVM has a minimum billable capacity (4 TiB by default, though this can vary by account). If the SVM's provisioned capacity is at or below that minimum, this value is rounded up to the minimum; otherwise it equals the provisioned capacity.
    Marketplace billing term
    The billing period for the associated marketplace subscription (for example, hourly or annual).
    Cloud Volumes ONTAP package or feature
    The licensing package or feature (for example, Essentials or Professional) associated with the SVM.
    Charging SaaS Marketplace subscription name
    The name of the marketplace subscription used for billing.
    Charging SaaS Marketplace subscription ID
    The unique identifier of the marketplace subscription used for billing.
    Workload type
    Indicates whether the SVM's volumes are Primary (read/write), actively used for production data, or Secondary (DP), data-protection destination volumes such as SnapMirror replicas used for backup and replication.
  • Volumes usage: This report shows how charged capacity is broken down by volumes in a Cloud Volumes ONTAP system. This information is not available on any screen in the Console. It includes the following information:
    Column Description
    System ID and name
    The unique identifier (UUID) and display name of the Cloud Volumes ONTAP system that contains the volume.
    SVM name
    The name of the storage virtual machine (SVM) that contains the volume.
    Volume ID
    The unique identifier of the volume.
    Volume type
    The type of volume (for example, read-write or data protection).
    Volume provisioned capacity
    The total capacity provisioned for the volume.
    Note FlexClone volumes aren't included in this report because these types of volumes don't incur charges.
Steps
  2. On the Overview tab, select View from the Cloud Volumes ONTAP tile.
  3. Select Usage report.
    The usage report downloads.
  4. Open the downloaded file to access the reports.
