Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Learn about data tiering with Cloud Volumes ONTAP in AWS, Azure, or Google Cloud
Contributors netapp-manini
Reduce your storage costs by enabling automated tiering of inactive data to low-cost object storage. Active data remains in high-performance SSDs or HDDs, while inactive data is tiered to low-cost object storage. This enables you to reclaim space on your primary storage and shrink secondary storage.
This is a conceptual image that shows hot data going to EBS storage and inactive data going to S3 storage.
Data tiering is powered by FabricPool technology. Cloud Volumes ONTAP provides data tiering for all Cloud Volumes ONTAP clusters without an additional license. When you enable data tiering, data tiered to object storage incurs charges. Refer to your cloud provider's documentation for details about object storage costs.
Data tiering in Google Cloud
When you enable data tiering in Google Cloud, Cloud Volumes ONTAP uses persistent disks as a performance tier for hot data and a Google Cloud Storage bucket as a capacity tier for inactive data. You can select a storage tier when you create a system and change it any time afterwards. For information about changing the storage class, refer to Tier inactive data to low-cost object storage.
Performance tier
The performance tier can be either SSD persistent disks, balanced persistent disks, or standard persistent disks.
Capacity tier
A Cloud Volumes ONTAP system tiers inactive data to a single Google Cloud Storage bucket.
The Console creates a bucket for each system and names it fabric-pool-cluster unique identifier. A different bucket is not created for each volume.
When the Console creates the bucket, it uses the following default settings:
  • Location type: Region
  • Storage class: Standard
  • Public access: Subject to object ACLs
  • Access control: Fine-grained
  • Protection: None
  • Data encryption: Google-managed key
Storage classes
Google Cloud uses storage classes to manage costs and data availability. We recommend that you select a storage class based on your expected data access frequency, because accessing data incurs higher costs. The default storage class for tiered data is Standard Storage. Unless manually changed, all inactive data maintains the default storage class. To change the storage class of inactive data, refer to Google Cloud documentation: Managing object lifecycles.
The storage class for data tiering is system wide—​it's not per volume.
Data tiering and capacity limits
If you enable data tiering, a system's capacity limit stays the same. The limit is spread across the performance tier and the capacity tier.
Volume tiering policies
To enable data tiering, you must select a volume tiering policy when you create, modify, or replicate a volume. You can select a different policy for each volume.
Some tiering policies have an associated minimum cooling period, which sets the time that user data in a volume must remain inactive for the data to be considered "cold" and moved to the capacity tier. The cooling period starts when data is written to the aggregate.
Tip You can change the minimum cooling period and default aggregate threshold of 50% (more on that below). Learn how to change the cooling period and learn how to change the threshold.
The Console enables you to choose from the following volume tiering policies when you create or modify a volume:
Snapshot Only
After an aggregate has reached 50% capacity, Cloud Volumes ONTAP tiers cold user data of Snapshot copies that are not associated with the active file system to the capacity tier. The cooling period is approximately 2 days.
If read, cold data blocks on the capacity tier become hot and are moved to the performance tier.
All
All data (not including metadata) is immediately marked as cold and tiered to object storage as soon as possible. There is no need to wait 48 hours for new blocks in a volume to become cold. Note that blocks located in the volume prior to the All policy being set require 48 hours to become cold.
If read, cold data blocks on the cloud tier stay cold and are not written back to the performance tier. This policy is available starting with ONTAP 9.6.
Auto
After an aggregate has reached 50% capacity, Cloud Volumes ONTAP tiers cold data blocks in a volume to a capacity tier. The cold data includes not just Snapshot copies but also cold user data from the active file system. The cooling period is approximately 31 days.
This policy is supported starting with Cloud Volumes ONTAP 9.4.
If read by random reads, the cold data blocks in the capacity tier become hot and move to the performance tier. If read by sequential reads, such as those associated with index and antivirus scans, the cold data blocks stay cold and do not move to the performance tier.
None
Keeps data of a volume in the performance tier, preventing it from being moved to the capacity tier.
Replication
When you replicate a volume, you can choose whether to tier the data to object storage. If you do, the Console applies the Backup policy to the data protection volume. Starting with Cloud Volumes ONTAP 9.6, the All tiering policy replaces the backup policy. When a replication relationship is deleted, the destination volume retains the tiering policy that was in effect during replication.
Turning off Cloud Volumes ONTAP impacts the cooling period
Data blocks are cooled by cooling scans. During this process, blocks that haven't been used have their block temperature moved (cooled) to the next lower value. The default cooling time depends on the volume tiering policy:
  • Auto: 31 days
  • Snapshot Only: 2 days
Cloud Volumes ONTAP must be running for the cooling scan to work. If Cloud Volumes ONTAP is turned off, cooling will stop, as well. As a result, you can experience longer cooling times.
Tip When Cloud Volumes ONTAP is turned off, the temperature of each block is preserved until you restart the system. For example, if the temperature of a block is 5 when you turn the system off, the temp is still 5 when you turn the system back on.
Setting up data tiering
For instructions and a list of supported configurations, refer to Tier inactive data to low-cost object storage.
