Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Tier inactive Cloud Volumes ONTAP data to a low-cost object storage
Contributors netapp-manini
You can reduce storage costs for Cloud Volumes ONTAP by combining an SSD or HDD performance tier for hot data with an object storage capacity tier for inactive data. Data tiering is powered by FabricPool technology. For a high-level overview, refer to Data tiering overview.
To set up data tiering, you need to do the following:
One Choose a supported configuration
Most configurations are supported. If you have a Cloud Volumes ONTAP system running the most recent version, then you are good to go. Learn more.
Two Ensure connectivity between Cloud Volumes ONTAP and object storage
  • For Google Cloud, you need to configure the subnet for Private Google Access and set up a service account. Learn more.
Three Ensure that you have an aggregate with tiering enabled
Data tiering should be enabled on an aggregate to enable it on a volume. You should be aware of the requirements for new volumes and for existing volumes. Learn more.
Four Choose a tiering policy when creating, modifying, or replicating a volume
The NetApp Console prompts you to choose a tiering policy when you create, modify, or replicate a volume.
Note
What's not required for data tiering?
  • You don't need to install a feature license to enable data tiering.
  • You don't need to create an object store for the capacity tier. The Console does that for you.
  • You don't need to enable data tiering at the system level.
    The Console creates an object store for cold data when it creates the system, as long as there are no connectivity or permissions issues. After that, you just need to enable data tiering on volumes (and in some cases, on aggregates).
Configurations that support data tiering
You can enable data tiering when using specific configurations and features.
Support in Google Cloud
  • Data tiering is supported in Google Cloud beginning with Cloud Volumes ONTAP 9.6.
  • The performance tier can be either SSD persistent disks, balanced persistent disks, or standard persistent disks.
  • The inactive data is tiered to Google Cloud Storage. Tiering to other providers is not supported.
Feature interoperability
  • Data tiering is supported with encryption technologies.
  • Thin provisioning must be enabled on volumes.
Requirements
Depending on your cloud provider, certain connections and permissions must be set up so that Cloud Volumes ONTAP can tier cold data to object storage.
Requirements to tier cold data to a Google Cloud Storage bucket
Enable data tiering after implementing the requirements
The Console creates an object store for cold data when the system is created, as long as there are no connectivity or permissions issues. If you didn't implement the requirements listed above until after you created the system, then you'll need to manually enable tiering through the API or ONTAP System Manager, which creates the object store.
Note The ability to enable tiering through the Console will be available in a future Cloud Volumes ONTAP release.
Ensure that tiering is enabled on aggregates
Data tiering must be enabled on an aggregate in order to enable data tiering on a volume. You should be aware of the requirements for new volumes and for existing volumes.
  • New volumes
    If you're enabling data tiering on a new volume, then you don't need to worry about enabling data tiering on an aggregate. The Console creates the volume on an existing aggregate that has tiering enabled, or it creates a new aggregate for the volume if a data tiering-enabled aggregate doesn't already exist.
  • Existing volumes
    To enable data tiering on an existing volume, ensure it is enabled on the underlying aggregate. If data tiering isn't enabled on the existing aggregate, then you'll need to use ONTAP System Manager to attach an existing aggregate to the object store.
Steps to confirm whether tiering is enabled on an aggregate
  1. From the left navigation menu, select Storage > Management.
  2. Open the Cloud Volumes ONTAP system.
  3. Select select the Aggregates tab and check if tiering is enabled or disabled on the aggregate.
    A screenshot that shows information about an aggregate in the Console which includes the tiering status.
Steps to enable tiering on an aggregate
  1. In ONTAP System Manager, click Storage > Tiers.
  2. Click the action menu for the aggregate and select Attach Cloud Tiers.
  3. Select the cloud tier to attach and click Save.
What's next?
You can now enable data tiering on new and existing volumes, as explained in the next section.
Tier data from read-write volumes
Cloud Volumes ONTAP can tier inactive data on read-write volumes to cost-effective object storage, freeing up the performance tier for hot data.
Steps
  1. In the Volumes tab under the system, create a new volume or change the tier of an existing volume:
    Task Action
    Create a new volume
    Click Add New Volume.
    Modify an existing volume
    Select the desired volume tile, click Manage volume to access the Manage Volumes right-side panel, and then click Advanced actions and Change tiering policy under the right panel.
  2. Select a tiering policy.
    For a description of these policies, refer to Data tiering overview.
    Example
    Screenshot that shows the options available to change tiering policy for a volume.
    The Console creates a new aggregate for the volume if a data tiering-enabled aggregate does not already exist.
Tier data from data protection volumes
Cloud Volumes ONTAP can tier data from a data protection volume to a capacity tier. If you activate the destination volume, the data gradually moves to the performance tier as it is read.
Steps
  2. On the Systems page, select the Cloud Volumes ONTAP system that contains the source volume, and then drag it to the system to which you want to replicate the volume.
  3. Follow the prompts until you reach the tiering page and enable data tiering to object storage.
    Example
    Screenshot that shows the S3 tiering option when replicating a volume.
    For help with replicating data, refer to Replicating data to and from the cloud.
Change the storage class for tiered data
After you deploy Cloud Volumes ONTAP, you can reduce your storage costs by changing the storage class for inactive data that hasn't been accessed for 30 days. The access costs are higher if you do access the data, so you must take that into consideration before you change the storage class.
The storage class for tiered data is system wide—​it's not per volume.
For information about supported storage classes, refer to Data tiering overview.
Steps
  1. On the Cloud Volumes ONTAP system, click the menu icon and then click Storage Classes or Blob Storage Tiering.
  2. Choose a storage class and then click Save.
Change the free space ratio for data tiering
The free space ratio for data tiering defines how much free space is required on Cloud Volumes ONTAP SSDs/HDDs when tiering data to object storage. The default setting is 10% free space, but you can tweak the setting based on your requirements.
For example, you might choose less than 10% free space to ensure that you are utilizing the purchased capacity. The Console can then purchase additional disks for you when additional capacity is required (up until you reach the disk limit for the aggregate).
Caution If there isn't sufficient space, then Cloud Volumes ONTAP can't move the data and you might experience performance degradation. Any change should be done with caution. If you're unsure, reach out to NetApp Support for guidance.
The ratio is important for disaster recovery scenarios because as data is read from the object store, Cloud Volumes ONTAP moves the data to SSDs/HDDs to provide better performance. If there isn't sufficient space, then Cloud Volumes ONTAP can't move the data. Take this into consideration when changing the ratio so that you can meet your business requirements.
Steps
  1. From the left navigation pane, go to Administration > Agents.
  2. Click the icon action icon for the Console agent that manages your Cloud Volumes ONTAP system.
  3. Select Cloud Volumes ONTAP Settings.
    A screenshot of the Cloud Volumes ONTAP Settings option under the Settings icon.
  4. Under Capacity, click Aggregate Capacity Thresholds - Free Space Ratio for Data Tiering.
    An overview of the capacity settings of Cloud Volumes ONTAP.
  5. Change the free space ratio based on your requirements and click Save.
Change the cooling period for the auto tiering policy
If you enabled data tiering on a Cloud Volumes ONTAP volume using the auto tiering policy, you can adjust the default cooling period based on your business needs. This action is supported using ONTAP CLI and API only.
The cooling period is the number of days that user data in a volume must remain inactive before it is considered "cold" and moved to object storage.
The default cooling period for the auto tiering policy is 31 days. You can change the cooling period as follows:
  • 9.8 or later: 2 days to 183 days
  • 9.7 or earlier: 2 days to 63 days
Step
  1. Use the minimumCoolingDays parameter with your API request when creating a volume or modifying an existing volume.
Remove an S3 bucket on decommissioning a system
You can delete an S3 bucket with the data tiered from a Cloud Volumes ONTAP system when you decommission the environment.
You can delete the S3 bucket only if:
  • The Cloud Volume ONTAP system is deleted from the Console.
  • All objects are deleted from the bucket and the S3 bucket is empty.
When you decommission a Cloud Volumes ONTAP system, the S3 bucket that was created for the environment is not deleted automatically. Instead, it remains in an orphaned state to prevent any accidental data loss. You can delete the objects in the bucket, then remove the S3 bucket itself, or keep it for later use.
Refer to ONTAP CLI: vserver object-store-server bucket delete.
