Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Convert existing Cloud Volumes ONTAP deployments to Infrastructure Manager
Contributors netapp-manini
Beginning on February 09, 2026, new Cloud Volumes ONTAP deployments in Google Cloud can use Google Cloud Infrastructure Manager. Google is about to deprecate Google Cloud Deployment Manager in favor of Infrastructure Manager. Therefore, you need to manually run a transition tool to convert your existing Cloud Volumes ONTAP deployments from Deployment Manager to Infrastructure Manager. This is a one-time process, after which your systems will automatically start using Infrastructure Manager.
About this task
The transition tool is available in the NetApp Support site, and creates the following artifacts:
  • Terraform artifacts, saved in conversion_output/deployment_name.
  • Summary of the conversion, saved in conversion_output/batch_summary_<deployment_name>_<timestamp>.json.
  • Debug logs, saved in the <gcp project number>-<region>-blueprint-config/<cvo name> directory. You need these logs for troubleshooting. The <gcp project number>-<region>-blueprint-config bucket stores the Terraform logs.
Caution
Cloud Volumes ONTAP systems using Infrastructure Manager store data and records in Google Cloud Storage buckets. You might incur extra costs for these buckets, but do not edit or delete the buckets or their content:
  • gs://netapp-cvo-infrastructure-manager-<project id>: for ONTAP versions and SVM Terraform Templates used for new Cloud Volumes ONTAP deployments. Inside this, the dm-to-im-convert bucket contains the Cloud Volumes ONTAP Terraform files.
  • <gcp project number>-<region>-blueprint-config: for storing Google Cloud Terraform artifacts.
Before you begin
  • Ensure that your Cloud Volumes ONTAP system is 9.16.1 or later.
  • Ensure that none of the Cloud Volumes ONTAP resources or their properties have been manually edited from the Google Cloud Console.
  • Ensure that the Google Cloud APIs are enabled. Refer to Enable Google Cloud APIs. Ensure that along with the other APIs, you enable the Google Cloud Quotas API.
  • Verify that the NetApp Console agent's service account has all required permissions. Refer to Google Cloud permissions for the Console agent.
    For private mode deployments, ensure these additional prerequisites:
    • Ensure that you have the latest Console agent version. Download the product installer from the NetApp Support Site and then manually install the agent on your host so that the agent can use Infrastructure Manager APIs.
    • If you are running the tool in a private mode, ensure that along with the other APIs, you have enabled the Cloud Build API. Enable Google Cloud APIs.
    • Ensure that you have completed the network configurations and created the worker pool for private mode deployments. Refer to Infrastructure Manager configuration for private mode deployments.
  • The conversion tool uses the following domains. Enable them on port 443 in your network:
    Domain Port Protocol Direction Purpose
    cloudresourcemanager.googleapis.com
    443
    TCP
    EGRESS
    Project validation
    deploymentmanager.googleapis.com
    443
    TCP
    EGRESS
    Deployment discovery
    config.googleapis.com
    443
    TCP
    EGRESS
    storage.googleapis.com
    443
    TCP
    EGRESS
    GCS bucket operations
    iam.googleapis.com
    443
    TCP
    EGRESS
    Service account validation
    compute.googleapis.com
    443
    TCP
    EGRESS
    Compute API calls used by Google Cloud and Terraform Import and Plan
    cloudbuild.googleapis.com
    443
    TCP
    EGRESS
    Build operations only required for private mode
    openidconnect.googleapis.com
    443
    TCP
    EGRESS
    Authentication
    oauth2.googleapis.com
    443
    TCP
    EGRESS
    OAuth2 token exchange
    registry.terraform.io
    443
    TCP
    EGRESS
    Terraform provider registry
    releases.hashicorp.com
    443
    TCP
    EGRESS
    Terraform binary downloads
    apt.releases.hashicorp.com
    443
    TCP
    EGRESS
    HashiCorp APT repository
    us-central1-docker.pkg.dev
    443
    TCP
    EGRESS
    GCP Artifact Registry
    metadata.google.internal
    80
    HTTP
    Internal
    VM metadata & auth tokens
    pypi.org
    443
    TCP
    EGRESS
    Python package index
    files.pythonhosted.org
    443
    TCP
    EGRESS
    Python package downloads
    checkpoint-api.hashicorp.com
    443
    TCP
    EGRESS
    Terraform version check
    download.docker.com
    443
    TCP
    EGRESS
    Docker APT repository
    security.ubuntu.com
    80/443
    TCP
    EGRESS
    Ubuntu security updates
    *.gce.archive.ubuntu.com
    80
    TCP
    EGRESS
    Ubuntu package mirror
Prepare the environment for running the tool
Run these steps before running the tool.
Steps
  1. Create a role and attach it to a service account:
    1. Create a YAML file with the following permissions:
      title: NetApp Dm TO IM Convert Solution
      description: Permissions for the service account associated with the VM where the tool will run.
      stage: GA
      includedPermissions:
      - compute.addresses.get
      - compute.disks.get
      - compute.forwardingRules.get
      - compute.healthChecks.get
      - compute.instanceGroups.get
      - compute.instances.get
      - compute.regionBackendServices.get
      - config.deployments.create
      - config.deployments.get
      - config.deployments.getLock
      - config.deployments.lock
      - config.deployments.unlock
      - config.deployments.update
      - config.deployments.delete
      - config.deployments.updateState
      - config.operations.get
      - deploymentmanager.deployments.get
      - deploymentmanager.deployments.list
      - deploymentmanager.manifests.get
      - iam.serviceAccounts.get
      - storage.buckets.create
      - storage.buckets.get
      - storage.objects.create
      - storage.objects.delete
      - storage.objects.get
      - storage.objects.list
      Include additional permission for private mode deployments
      If you are running the tool in a private mode, add the cloudbuild.workerpools.get permission also to the YAML file.
    2. Create a custom role in Google Cloud with the permissions defined in the YAML file.
      gcloud iam roles create dmtoim_convert_tool_role --project=PROJECT_ID \
      --file=YAML_FILE_PATH
      For more information, refer to Creating and managing custom roles.
    3. Attach the custom role to the service account that you'll use to create the VM.
    4. Add the roles/iam.serviceAccountUser role to this service account. Refer to Service accounts overview.
  2. Create a VM with the following configurations. You run the tool on this VM.
    • Machine Type: Google Compute Engine machine type e2-medium
    • OS: Based on your requirement, select either of these images:
      • Ubuntu 25.10 AMD64 Minimal (image: ubuntu-minimal-2510-amd64)
      • SUSE Linux Enterprise Server 15 SP7 x86_64
    • Networking: Firewall allowing HTTP and HTTPs
    • Disk Size: 20GB
    • Security: Service accounts: the service account you created
    • Security: Access Scope - access set for each API:
      • Cloud Platform: Enabled
      • Compute Engine: Read only
      • Storage: Read only (default)
      • Google Cloud Logging (previously Stackdriver Logging) API: Write only (default)
      • Stackdriver Monitoring (now part of Google Cloud Operations) API: Write only (default)
      • Service Management: Read only (default)
      • Service Control: Enabled (default)
      • Google Cloud Trace (previously Stackdriver Trace): Write only (default)
  3. Connect to the newly created VM using SSH: gcloud compute ssh dmtoim-convert-executor-vm --zone <region where VM is deployed>
  4. Download the conversion tool from the NetApp Support site by using your NSS credentials: wget <download link from NetApp Support site>
  5. Extract the downloaded TAR file: unzip <downloaded file name>
Ubuntu
  1. Download and install these prerequisite packages:
    • Docker: 28.2.2 build 28.2.2-0ubuntu1 or later
    • Terraform: 1.14.1 or later
    • Python: 3.13.7, python3-pip, python3 venv
      sudo apt-get update
      sudo apt-get install python3-pip python3-venv -y
      wget -O - https://apt.releases.hashicorp.com/gpg | sudo gpg --dearmor -o /usr/share/keyrings/hashicorp-archive-keyring.gpg
      echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/hashicorp-archive-keyring.gpg] https://apt.releases.hashicorp.com noble main" | sudo tee /etc/apt/sources.list.d/hashicorp.list
      sudo apt update && sudo apt install terraform
      sudo apt-get install -y docker.io
      sudo systemctl start docker
      Google Cloud CLI gcloud is preinstalled on the VM.
  1. Set up Python: sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.11 2
  2. Install pip3 for installing the package: python3.11 -m ensurepip --upgrade
  3. Install Terraform:
    wget https://releases.hashicorp.com/terraform/1.7.4/terraform_1.7.4_linux_amd64.zip
    unzip terraform_1.7.4_linux_amd64.zip
    sudo mv terraform /usr/local/bin/
    rm terraform_1.7.4_linux_amd64.zip
  4. Install Google Cloud SDK (gcloud)
    curl https://sdk.cloud.google.com | bash
    exec -l $SHELL
Run the conversion tool
These steps are for both Ubuntu and SUSE Linux Enterprise Server for running the conversion tool.
Steps
  1. Add the current user to the Docker group, so that the tool can use Docker without sudo privileges.
    sudo usermod -aG docker $USER
    newgrp docker
  2. Install the conversion tool:
    cd <folder where you extracted the tool>
     ./install.sh
    This installs the tool in an isolated environment, dmconvert-venv, and verifies that all required software packages are installed.
  3. Enter the environment where the tool is installed: source dmconvert-venv/bin/activate
  4. Run the conversion tool as a non-sudo user. Ensure that you use the same service account as the Console agent's service account, and that the service account has all the necessary permissions for Google Cloud Infrastructure Manager.
    dmconvert \
    --project-id=<the Google Cloud project ID for the Cloud Volumes ONTAP deployment> \
    --cvo-name=<Cloud Volumes ONTAP system name> \
    --service-account=<the service account attached to the Console agent>
    Run the tool in private mode deployments
    Specify the --worker-pool parameter to run the tool in private mode deployments. For worker pool configuration, refer to Infrastructure Manager configuration for private mode deployments.
    dmconvert \
    --service-account=<the service account attached to the Console agent> \
    --worker-pool=<worker pool name>
After you finish
The tool displays a list of all Cloud Volumes ONTAP systems and SVM details. When it finishes running, you can see the statuses of all the converted systems. Each converted system appears in the Google Console under Infrastructure Manager in a <system-name-imdeploy> format, indicating that the Console now uses Infrastructure Manager APIs to manage that Cloud Volumes ONTAP system.
Caution Post conversion, do not delete the deployment object for Deployment Manager in the Google Cloud Console. This deployment object contains information that you might need to roll back the converted system.
If you need to roll back the conversion, you must use the same VM. If you have converted all systems and do not need to roll back to Deployment Manager, you can delete the VM.
Roll back the conversion
If you don't want to continue with the conversion, you can roll back to Deployment Manager by following these steps:
Steps
  1. On the same VM that you created for running the tool, run this command:
    dmconvert \
    --rollback
  2. Wait till the rollback is complete.
