Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Set up Google Cloud networking for Cloud Volumes ONTAP
Contributors netapp-manini
The NetApp Console handles the set up of networking components for Cloud Volumes ONTAP, such as IP addresses, netmasks, and routes. You need to make sure that outbound internet access is available, that enough private IP addresses are available, that the right connections are in place, and more.
If you want to deploy an HA pair, you should learn how HA pairs work in Google Cloud.
Requirements for Cloud Volumes ONTAP
The following requirements must be met in Google Cloud.
Requirements specific to single-node systems
If you want to deploy a single-node system, ensure that your networking meets the following requirements.
One VPC
One Virtual Private Cloud (VPC) is required for a single-node system.
Private IP addresses
For a single-node system in Google Cloud, the Console allocates private IP addresses to the following:
  • Node
  • Cluster
  • Storage VM
  • Data NAS LIF
  • Data iSCSI LIF
You can skip creation of the storage VM (SVM) management LIF if you deploy Cloud Volumes ONTAP using the API and specify the following flag:
skipSvmManagementLif: true
Note A LIF is an IP address associated with a physical port. A storage VM (SVM) management LIF is required for management tools like SnapCenter.
Requirements specific to HA pairs
If you want to deploy an HA pair, ensure that your networking meets the following requirements.
One or multiple zones
You can ensure the high availability of your data by deploying an HA configuration across multiple or in a single zone. The Console prompts you to choose multiple zones or a single zone when you create the HA pair.
  • Multiple zones (recommended)
    Deploying an HA configuration across three zones ensures continuous data availability if a failure occurs within a zone. Note that write performance is slightly lower compared to using a single zone, but it's minimal.
  • Single zone
    When deployed in a single zone, a Cloud Volumes ONTAP HA configuration uses a spread placement policy. This policy ensures that an HA configuration is protected from a single point of failure within the zone, without having to use separate zones to achieve fault isolation.
    This deployment model does lower your costs because there are no data egress charges between zones.
Four Virtual Private Clouds
Four Virtual Private Clouds (VPCs) are required for an HA configuration. Four VPCs are required because Google Cloud requires that each network interface resides in a separate VPC network.
The Console prompts you to choose four VPCs when you create the HA pair:
  • VPC-0 for inbound connections to the data and nodes
  • VPC-1, VPC-2, and VPC-3 for internal communication between the nodes and the HA mediator
A conceptual image showing a Cloud Volume HA pair and the four VPCs required for configuration.
Subnets
A private subnet is required for each VPC.
If you place the Console agent in VPC-0, then you will need to enable Private Google Access on the subnet to access the APIs and to enable data tiering.
The subnets in these VPCs must have distinct CIDR ranges. They can't have overlapping CIDR ranges.
The Console automatically allocates the required number of private IP addresses to Cloud Volumes ONTAP in Google Cloud. You need to make sure that your networking has enough private addresses available.
The number of LIFs allocated for Cloud Volumes ONTAP depends on whether you deploy a single-node system or an HA pair. A LIF is an IP address associated with a physical port. An SVM management LIF is required for management tools like SnapCenter.
  • Single node
    The Console allocates 4 IP addresses to a single-node system:
    • Node management LIF
    • Cluster management LIF
    • iSCSI data LIF
      Note An iSCSI LIF provides client access over the iSCSI protocol and is used by the system for other important networking workflows. These LIFs are required and should not be deleted.
    • NAS LIF
  • HA pair
    The Console allocates 12-13 IP addresses to an HA pair:
    • 2 Node management LIFs (e0a)
    • 1 Cluster management LIF (e0a)
    • 2 iSCSI LIFs (e0a)
    • 1 or 2 NAS LIFs (e0a)
    • 2 Cluster LIFs (e0b)
    • 2 HA Interconnect IP addresses (e0c)
    • 2 RSM iSCSI IP addresses (e0d)
Internal load balancers
The Console creates four Google Cloud internal load balancers (TCP/UDP) that manage incoming traffic to the Cloud Volumes ONTAP HA pair. No setup is required from your end. We've listed this as a requirement simply to inform you of the network traffic and to mitigate any security concerns.
One load balancer is for cluster management, one is for storage VM (SVM) management, one is for NAS traffic to node 1, and the last is for NAS traffic to node 2.
The setup for each load balancer is as follows:
  • One shared private IP address
  • One global health check
    By default, the ports used by the health check are 63001, 63002, and 63003.
  • One regional TCP backend service
  • One regional UDP backend service
  • One TCP forwarding rule
  • One UDP forwarding rule
  • Global access is disabled
    Even though global access is disabled by default, enabling it post deployment is supported. We disabled it because cross region traffic will have significantly higher latencies. We wanted to ensure that you didn't have a negative experience due to accidental cross region mounts. Enabling this option is specific to your business needs.
Shared VPCs
Cloud Volumes ONTAP and the Console agent are supported in a Google Cloud shared VPC and also in standalone VPCs.
For a single-node system, the VPC can be either a shared VPC or a standalone VPC.
For an HA pair, four VPCs are required. Each of those VPCs can be either shared or standalone. For example, VPC-0 could be a shared VPC, while VPC-1, VPC-2, and VPC-3 could be standalone VPCs.
A shared VPC enables you to configure and centrally manage virtual networks across multiple projects. You can set up shared VPC networks in the host project and deploy the Console agent and Cloud Volumes ONTAP virtual machine instances in a service project.
Packet mirroring in VPCs
Packet mirroring must be disabled in the Google Cloud subnet in which you deploy Cloud Volumes ONTAP.
Outbound internet access
Cloud Volumes ONTAP systems require outbound internet access for accessing external endpoints for various functions. Cloud Volumes ONTAP can't operate properly if these endpoints are blocked in environments with strict security requirements.
The Console agent also contacts several endpoints for day-to-day operations. For information about the endpoints, refer to View endpoints contacted from the Console agent and Prepare networking for using the Console.
Cloud Volumes ONTAP endpoints
Cloud Volumes ONTAP uses these endpoints to communicate with various services.
Endpoints Applicable for Purpose Deployment mode Impact if endpoint is not available
https://netapp-cloud-account.auth0.com
Authentication
Used for authentication in the Console.
Standard and restricted modes.
User authentication fails and the following services remain unavailable:
  • Cloud Volumes ONTAP services
  • ONTAP services
  • Protocols and proxy services
https://api.bluexp.netapp.com/tenancy
Tenancy
Used to retrieve Cloud Volumes ONTAP resource from the Console to authorize resources and users.
Cloud Volumes ONTAP resources and the users are not authorized.
https://mysupport.netapp.com/aods/asupmessage
https://mysupport.netapp.com/asupprod/post/1.0/postAsup
AutoSupport
Used to send AutoSupport telemetry data to NetApp support.
AutoSupport information remains undelivered.
https://cloudbuild.googleapis.com/v1 (for only private mode deployments)
https://cloudkms.googleapis.com/v1
https://cloudresourcemanager.googleapis.com/v1/projects
https://compute.googleapis.com/compute/v1
https://www.googleapis.com/compute/beta
https://www.googleapis.com/compute/v1/projects/
https://www.googleapis.com/deploymentmanager/v2/projects
https://www.googleapis.com/storage/v1
https://www.googleapis.com/upload/storage/v1
https://config.googleapis.com/v1
https://iam.googleapis.com/v1
https://storage.googleapis.com/storage/v1
Google Cloud (Commercial use).
Communication with Google Cloud services.
Standard, restricted, and private modes.
Cloud Volumes ONTAP cannot communicate with Google Cloud service to perform specific operations for the Console in Google Cloud.
Connections to ONTAP systems in other networks
To replicate data between a Cloud Volumes ONTAP system in Google Cloud and ONTAP systems in other networks, you must have a VPN connection between the VPC and the other network—for example, your corporate network.
Firewall rules
The Console creates Google Cloud firewall rules that include the inbound and outbound rules that Cloud Volumes ONTAP needs to operate successfully. You might want to refer to the ports for testing purposes or if you prefer to use your own firewall rules.
The firewall rules for Cloud Volumes ONTAP requires both inbound and outbound rules. If you're deploying an HA configuration, these are the firewall rules for Cloud Volumes ONTAP in VPC-0.
Note that two sets of firewall rules are required for an HA configuration:
  • One set of rules for HA components in VPC-0. These rules enable data access to Cloud Volumes ONTAP.
  • Another set of rules for HA components in VPC-1, VPC-2, and VPC-3. These rules are open for inbound & outbound communication between the HA components. Learn more.
Tip Looking for information about the Console agent? View firewall rules for the Console agent
Inbound rules
When you add a Cloud Volumes ONTAP system, you can choose the source filter for the predefined firewall policy during deployment:
  • Selected VPC only: the source filter for inbound traffic is the subnet range of the VPC for the Cloud Volumes ONTAP system and the subnet range of the VPC where the Console agent resides. This is the recommended option.
  • All VPCs: the source filter for inbound traffic is the 0.0.0.0/0 IP range.
If you use your own firewall policy, ensure that you add all networks that need to communicate with Cloud Volumes ONTAP, but also ensure to add both address ranges to allow the internal Google Load Balancer to function correctly. These addresses are 130.211.0.0/22 and 35.191.0.0/16. For more information, refer to the Google Cloud documentation: Load Balancer Firewall Rules.
Protocol Port Purpose
All ICMP
All
Pinging the instance
HTTP
80
HTTP access to the ONTAP System Manager web console using the IP address of the cluster management LIF
HTTPS
443
Connectivity with the Console agent and HTTPS access to the ONTAP System Manager web console using the IP address of the cluster management LIF
SSH
22
SSH access to the IP address of the cluster management LIF or a node management LIF
TCP
111
Remote procedure call for NFS
TCP
139
NetBIOS service session for CIFS
TCP
161-162
Simple network management protocol
TCP
445
Microsoft SMB/CIFS over TCP with NetBIOS framing
TCP
635
NFS mount
TCP
749
Kerberos
TCP
2049
NFS server daemon
TCP
3260
iSCSI access through the iSCSI data LIF
TCP
4045
NFS lock daemon
TCP
4046
Network status monitor for NFS
TCP
10000
Backup using NDMP
TCP
11104
Management of intercluster communication sessions for SnapMirror
TCP
11105
SnapMirror data transfer using intercluster LIFs
TCP
63001-63050
Load balance probe ports to determine which node is healthy (required for HA pairs only)
UDP
111
UDP
161-162
UDP
635
NFS mount
UDP
2049
NFS server daemon
UDP
4045
NFS lock daemon
UDP
4046
UDP
4049
NFS rquotad protocol
Outbound rules
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
All ICMP
All
All outbound traffic
All TCP
All
All UDP
All
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP. The Cloud Volumes ONTAP clusters use the following ports for regulating nodes traffic.
Note The source is the interface (IP address) of the Cloud Volumes ONTAP system.
Service Protocol Port Source Destination Purpose
Active Directory
TCP
88
Node management LIF
Active Directory forest
Kerberos V authentication
UDP
137
Node management LIF
NetBIOS name service
UDP
138
Node management LIF
NetBIOS datagram service
TCP
139
Node management LIF
TCP & UDP
389
Node management LIF
LDAP
TCP
445
Node management LIF
TCP
464
Node management LIF
Kerberos V change & set password (SET_CHANGE)
UDP
464
Node management LIF
Kerberos key administration
TCP
749
Node management LIF
Kerberos V change & set Password (RPCSEC_GSS)
TCP
88
Data LIF (NFS, CIFS, iSCSI)
UDP
137
Data LIF (NFS, CIFS)
UDP
138
TCP
139
TCP & UDP
389
LDAP
TCP
445
TCP
464
UDP
464
TCP
749
Kerberos V change & set password (RPCSEC_GSS)
AutoSupport
HTTPS
443
Node management LIF
AutoSupport (HTTPS is the default)
HTTP
80
Node management LIF
AutoSupport (only if the transport protocol is changed from HTTPS to HTTP)
TCP
3128
Node management LIF
Console agent
Sending AutoSupport messages through a proxy server on the Console agent, if an outbound internet connection isn't available
Configuration backups
HTTP
80
Node management LIF
http://<console-agent-IP-address>/occm/offboxconfig
Send configuration backups to the Console agent. ONTAP documentation
DHCP
UDP
68
Node management LIF
DHCP
DHCP client for first-time setup
DHCPS
UDP
67
Node management LIF
DHCP
DHCP server
DNS
UDP
53
Node management LIF and data LIF (NFS, CIFS)
DNS
DNS
NDMP
TCP
18600–18699
Node management LIF
Destination servers
NDMP copy
SMTP
TCP
25
Node management LIF
Mail server
SMTP alerts, can be used for AutoSupport
SNMP
TCP
161
Node management LIF
Monitor server
Monitoring by SNMP traps
UDP
161
Node management LIF
Monitor server
TCP
162
Node management LIF
Monitor server
UDP
162
Node management LIF
Monitor server
SnapMirror
TCP
11104
Intercluster LIF
ONTAP intercluster LIFs
TCP
11105
Intercluster LIF
Syslog
UDP
514
Node management LIF
Syslog server
Syslog forward messages
Rules for VPC-1, VPC-2, and VPC-3
In Google Cloud, an HA configuration is deployed across four VPCs. The firewall rules needed for the HA configuration in VPC-0 are listed above for Cloud Volumes ONTAP.
Meanwhile, the predefined firewall rules created for the instances in VPC-1, VPC-2, and VPC-3 enable ingress communication over all protocols and ports. These rules enable communication between HA nodes.
Communication from the HA nodes to the HA mediator takes place over port 3260 (iSCSI).
Note To enable high write speed for new Google Cloud HA pair deployments, a maximum transmission unit (MTU) of at least 8,896 bytes is required for VPC-1, VPC-2, and VPC-3. If you choose to upgrade existing VPC-1, VPC-2, and VPC-3 to an MTU of 8,896 bytes, you must shutdown all existing HA systems using these VPCs during the configuration process.
Infrastructure Manager configuration for private mode deployments
If you want to deploy Cloud Volumes ONTAP 9.16.1 or later in private mode, you need to make a few configuration changes so that Cloud Volumes ONTAP can use Google Cloud Infrastructure Manager as the deployment service instead of Deployment Manager, which Google will eventually deprecate.
Before you begin
Steps
  1. Create a private worker pool with this configuration in the same region as the Cloud Volumes ONTAP deployments. For information about creating a private worker pool, refer to Google Cloud documentation: Create and manage private pools and Google Cloud Build pricing.
    The worker pool must have the following configuration:
    • Machine type: e2-medium
    • Disk size: 100 GB
    • Assign external IP: False
    • Network: Default or a private.
    • The subnet configured to access Google Cloud APIs. Perform these steps to ensure that the subnet can access Google APIs:
      1. Ensure "Private Google Access" is turned on for the subnet.
      2. Go to VPC Network level > Private Service Access Tab > Allocated IP ranges for services.
      3. Select Allocate IP range and allocate the internal IP range for the private connection to the Google Compute Service.
      4. On Private connection to services, select Create Connection.
      5. Select Connected service producer = Google Cloud Platform.
      6. Assign the allocation for the private connection IP range you created in the previous step.
  2. Deploy this worker pool and keep it running for Cloud Volumes ONTAP management. Google Cloud uses this worker pool to run all Terraform operations in an isolated environment.
  3. When deploying Cloud Volumes ONTAP in private mode, select the name of this worker pool in the GCP Worker Pool field. Refer to Launch Cloud Volumes ONTAP in Google Cloud for instructions.
Requirements for the Console agent
If you haven't created a Console agent yet, you should review networking requirements.
Network configurations to support Console agent proxy
You can use the proxy servers configured for the Console agent to enable outbound internet access from Cloud Volumes ONTAP. The Console supports two types of proxies:
  • Explicit proxy: The outbound traffic from Cloud Volumes ONTAP uses the HTTP address of the proxy server specified during the Console agent proxy configuration. The Console agent administrator might also have configured user credentials and root CA certificates for additional authentication. If a root CA certificate is available for the explicit proxy, make sure to obtain and upload the same certificate to your Cloud Volumes ONTAP system using the ONTAP CLI: security certificate install command.
  • Transparent proxy: The network is configured to automatically route outbound traffic from Cloud Volumes ONTAP through the Console agent proxy. When setting up a transparent proxy, the Console agent administrator needs to provide only a root CA certificate for connectivity from Cloud Volumes ONTAP, not the HTTP address of the proxy server. Make sure that you obtain and upload the same root CA certificate to your Cloud Volumes ONTAP system using the ONTAP CLI: security certificate install command.
For information about configuring proxy servers for the Console agent, refer to the Configure a Console agent to use a proxy server.
Configure network tags for Cloud Volumes ONTAP in Google Cloud
During the transparent proxy configuration of the Console agent, the administrator adds a network tag for Google Cloud. You need to obtain and manually add the same network tag for your Cloud Volumes ONTAP configuration. This tag is necessary for the proxy server to function correctly.
  1. In the Google Cloud Console, locate your Cloud Volumes ONTAP system.
  2. Go to Details > Networking > Network tags.
  3. Add the tag used for the Console agent and save the configuration.
