Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Verify AutoSupport setup for Cloud Volumes ONTAP
Contributors netapp-manini
AutoSupport proactively monitors the health of your system and sends messages to NetApp technical support. By default, AutoSupport is enabled on each node to send messages to technical support using the HTTPS transport protocol. It's best to verify that AutoSupport can send these messages.
The only required configuration step is to ensure that Cloud Volumes ONTAP has outbound internet connectivity. For details, refer to the networking requirements for your cloud provider.
AutoSupport requirements
Cloud Volumes ONTAP nodes require outbound internet access for NetApp AutoSupport, which proactively monitors the health of your system and sends messages to NetApp technical support.
Routing and firewall policies must allow HTTPS traffic to the following endpoints so Cloud Volumes ONTAP can send AutoSupport messages:
  • https://mysupport.netapp.com/aods/asupmessage
  • https://mysupport.netapp.com/asupprod/post/1.0/postAsup
If an outbound internet connection isn't available to send AutoSupport messages, the NetApp Console automatically configures your Cloud Volumes ONTAP systems to use the Console agent as a proxy server. The only requirement is to ensure that the Console agent's security group allows inbound connections over port 3128. You'll need to open this port after you deploy the Console agent.
If you defined strict outbound rules for Cloud Volumes ONTAP, then you'll also need to ensure that the Cloud Volumes ONTAP security group allows outbound connections over port 3128.
Tip If you're using an HA pair, the HA mediator doesn't require outbound internet access.
After you've verified that outbound internet access is available, you can test AutoSupport to ensure that it can send messages. For instructions, refer to the ONTAP documentation: Set up AutoSupport.
Troubleshoot your AutoSupport configuration
If an outbound connection isn't available and the Console can't configure your Cloud Volumes ONTAP system to use the Console agent as a proxy server, you'll receive a notification from the Console that your system is unable to send AutoSupport messages. Follow these steps to address this issue.
Steps
  1. Connect securely (using SSH) to the Cloud Volumes ONTAP system to use the ONTAP CLI.
  2. Check the detailed status of the AutoSupport subsystem:
    autosupport check show-details
    The response looks like this:
        Category: smtp
              Component: mail-server
                 Status: failed
                 Detail: SMTP connectivity check failed for destination:
                         mailhost. Error: Could not resolve host - 'mailhost'
                Corrective Action: Check the hostname of the SMTP server
        Category: http-https
            Component: http-put-destination
                Status: ok
                Detail: Successfully connected to:
                        <https://support.netapp.com/put/AsupPut/>.
              Component: http-post-destination
                 Status: ok
                         https://support.netapp.com/asupprod/post/1.0/postAsup.
        Category: on-demand
              Component: ondemand-server
                 Status: ok
                         https://support.netapp.com/aods/asupmessage.
        Category: configuration
                Component: configuration
                    Status: ok
                    Detail: No configuration issues found.
        5 entries were displayed.
    If the status of the http-https category is OK it means that AutoSupport is configured properly and messages can be sent.
  3. If not, verify the proxy URL for each Cloud Volumes ONTAP node:
    autosupport show -fields proxy-url
  4. If the proxy URL parameter is empty, configure Cloud Volumes ONTAP to use the Console agent as a proxy:
    autosupport modify -proxy-url http://<console agent private ip>:3128
  5. Verify the AutoSupport status again:
  6. If the status is still failed, validate that there is connectivity between Cloud Volumes ONTAP and the Console agent over port 3128.
  7. If the status is still failed after verification, SSH to the Console agent.
  8. Go to /opt/application/netapp/cloudmanager/docker_occm/data/.
  9. Open the proxy configuration file squid.conf. This is the structure of the file:
            http_port 3128
            acl netapp_support dst support.netapp.com
            http_access allow netapp_support
            request_header_max_size 21 KB
            reply_header_max_size 21 KB
            http_access deny all
            httpd_suppress_version_string on
  10. If your file doesn't have an entry for the CIDR block of the Cloud Volumes ONTAP system, add a new entry and allow access:
    acl cvonet src <cidr>
    http_access allow cvonet
    Here's an example:
            http_port 3128
  11. After editing the config file, restart the proxy container as sudo. Then, depending on whether you're using Docker or Podman, run these commands:
    For Docker, run docker restart squid.
    If you are using Podman, run podman restart squid.
  12. Go back to the ONTAP CLI and verify that Cloud Volumes ONTAP can send AutoSupport messages:
