Maintain the Connector VM and operating system
Maintaining the operating system on the Connector host is your (the customer's) responsibility. For example, you (the customer) should apply security updates to the operating system on the Connector host by following your company's standard procedures for operating system distribution.
If you have an existing Connector, you should be aware of changes to supported Linux operating systems. |
Operating system patches and the Connector
Apply OS security patches without stopping Connector host services.
VM or instance type
If you create a Connector from BlueXP, it deploys a VM instance in your cloud provider with a default configuration. After you create the Connector, don't switch to a smaller VM instance with less CPU or RAM.
The following table lists the CPU and RAM requirements:
- CPU
8 cores or 8 vCPUs
- RAM
32 GB
Monitor the Connector
BlueXP notifies you when the Connector VM is unhealthy, including disk space, RAM, and CPU issues. Monitor these notifications in the Notifications Center within BlueXP or configure email notifications. Occasional increases in disk space, memory, or CPU usage are normal, but if it happens frequently, you should take steps to resolve.
BlueXP notifies you when a Connector resource (CPU, RAM, or disk space) exceeds 90% of its total capacity for 30 consecutive minutes. Afterwards, if the resource usage drops below that threshold, the notification displays as resolved (green) in the Notifications Center.
Work with NetApp support if you have questions about modifying your Connector VM. |
Notification | Action needed |
Disk space is too high |
CPU usage is too high |
Increase the CPU size of the Connector VM in your hyperscaler or on-premises, depending on where you installed it. Alternatively, create additional Connectors and distribute the workload across multiple Connectors. RAM utilization can vary based on your environment, ONTAP workloads, number of Cloud Volumes ONTAP systems, and the data services that you are using. |
RAM usage is too high |
Increase the RAM of the Connector VM in your hyperscaler or on-premises, depending on where you installed it. Alternatively, create additional Connectors and distribute the workload across multiple Connectors. RAM utilization can vary based on your environment, ONTAP workloads, number of Cloud Volumes ONTAP systems, and the data services that you are using. |
Stopping and starting the Connector VM
If you need to, stop and start the Connector VM using your cloud provider's console or standard on-premises procedures.
Connect to the Linux VM
If you need to connect to the Linux VM that the Connector runs on, use the connectivity options from your cloud provider.
- AWS
When you create the Connector instance in AWS, provide an AWS access key and secret key. You can use this key pair to SSH to the instance. Use the user name 'ubuntu' for the EC2 Linux instance. For Connectors created prior to May 2023, use the user name 'ec2-user'.
- Azure
When you create the Connector VM in Azure, you specify a user name and choose to authenticate with a password or SSH public key. Use the authentication method that you chose to connect to the VM.
- Google Cloud
You can't specify an authentication method when you create a Connector in Google Cloud. However, you can connect to the Linux VM instance using the Google Cloud Console or Google Cloud CLI (gcloud).
Change the IP address for a Connector
You can change the internal and public IP addresses of the Connector instance assigned by your cloud provider if needed.
Follow the instructions from your cloud provider to change the local IP address or public IP address (or both) for the Connector instance.
Restart the Connector instance to register a new public IP address with BlueXP.
If you changed the private IP address, update the backup location for Cloud Volumes ONTAP configuration files so that the backups are being sent to the new private IP address on the Connector.
Update the backup location for each Cloud Volumes ONTAP system.
From the Cloud Volumes ONTAP CLI, set the privilege level to advanced:
set -privilege advanced
Run the following command to display the current backup target:
system configuration backup settings show
Run the following command to update the IP address for the backup target:
system configuration backup settings modify -destination <target-location>
Edit a Connector's URIs
You can add and remove the Uniform Resource Identifier (URI) for a Connector.
Select the Connector drop-down from the BlueXP header.
Select Manage Connectors.
Expand the Connector URIs bar to view connector URIs.
Add and remove URIs and then select Apply.
