Add members to a NetApp Console organization
Within the Console, you grant users access to projects or folders according to an access role. An access role contains a set of permissions that enables a member (user or service account) to perform specific actions at the assigned level of the resource hierarchy.
Super admin, Org admin, or Folder or project admin (for folders and projects that they are administering). Learn about access roles.
Understand how access is granted in NetApp Console
The NetApp Console uses role-based access control (RBAC) to manage permissions. Assign roles to users individually or through federated groups. Each role defines allowed actions for specific resources.
Note the following about granting access in NetApp Console:
All users must first sign up for the NetApp Console before they can be granted access to resources, even if they are part of a federated group.
You must explicitly assign a role to each user in the Console before they can access resources, even if they are members of a federated group that has been assigned a role.
You can add service accounts directly from the Console and assign them roles.
You can choose from supported roles when assigning roles to users or service accounts.
Add members to your organization
NetApp Console supports three types of members: user accounts, service accounts, and federated groups.
Users must sign up for NetApp Console before you can add them and assign a role, even if they are in a federated group. Create service accounts directly in the Console.
All members must have at least one role explicitly assigned to them in order to access resources.
When adding a member, choose the resource level (organization, folder, or project) and assign a role or roles with the needed permissions.
Add a user
Users sign up for the NetApp Console, but an Org admin or Folder or project admin must add them to an organization, folder, or project so they can access resources.
The user must have already signed up for the NetApp Console. If they haven't signed up yet, direct them to sign up for the NetApp Console.
If you are adding a user that is part of a federated group, ensure that the user has already signed up for the NetApp Console and been explicitly assigned a role in the Console. NetApp recommends assigning a minimum access role, such as Organization viewer. |
Select Administration > Identity and access.
Select Members.
Select Add a member.
For Member Type, keep User selected.
For User's email, enter the user's email address that is associated with the login that they created.
Use the Select an organization, folder, or project section to choose the level of your resource hierarchy that the member should have permissions for.
Note the following:
You can select only the folders and projects for which you have permissions.
When you select an organization or folder, you grant the member permissions to all its contents.
You can only assign the Organization admin role at the organization level.
Select a category then select a Role that provides the member with permissions for the resources that are associated with the organization, folder, or project that you selected.
Only supported roles are displayed in the drop-down list. Learn about access roles.
To give access to more folders, projects, or roles, select Add role, choose the folder, project, or role category, and select a role.
Select Add.
The Console emails instructions to the user.
Add a service account
Service accounts allow you to automate tasks and securely connect with Console APIs. Choose a client ID and secret for simple setups, or JWT (JSON Web Token) for stronger security in automated or cloud-native environments. Select the method that meets your security requirements.
For JWT authentication, prepare your public key or certificate.
Select Members.
For Member Type, select Service account.
Enter a name for the service account.
To use JWT authentication, select Use private key JWT authentication and upload your public RSA key or certificate. Skip if using client ID and secret.
Upload your X.509 certificate in PEM, CRT, or CER format.
Set up expiry notifications for your certificate. Choose between seven days or 30 days. Expiry notifications are emailed and shown in the Console to users with the Super admin or Org admin role.
Note the following:
You can only select from the folders and projects for which you have permissions.
Selecting an organization or folder grants the member permissions to all its contents.
Select a Category then select a Role that gives the member permissions for the resources in the organization, folder, or project you selected.
If you didn't use JWT authentication, download or copy the client ID and client secret.
The Console shows the client secret only once. Copy it securely; you can recreate it later if you lose it.
If you chose JWT authentication, download or copy the client ID and JWT audience. The Console displays this information only once and does not allow you to retrieve it later.
Select Close.
Add a federated group to your organization
You can add a federated group from your identity provider (IdP) to your organization and assign it a role or roles. Members of the federated group inherit the roles that you assign to the group in the Console.
When you add a federated group to the Console and assign it a role, only users that are members of the group in your IdP and have already signed up for the NetApp Console and been explicitly assigned a role in the Console can access resources. NetApp recommends assigning a minimum access role, such as Organization viewer, to these users. |
Before you can assign a role to a federated group, ensure the following:
Set up federation between your IdP and the Console. Learn how to set up federation.
The group must already exist in your IdP and have been assigned app access to the Console.
Select Members.
For Member Type, select Federated Group.
Select the federation of which the group is a member.
For Group name, enter the exact name of the group in your IdP.
Note the following:
