Organization and project IDs
Your BlueXP organization has a name and an ID. You can choose a name for your organization to help identify it in your BlueXP deployment. You may also need to retrieve the organization ID for certain integrations.
Rename your organization
You can rename your organization within BlueXP. This is helpful if you support more than organization within your BlueXP deployment.
In the upper right of the BlueXP console, select
> Identity & Access Management.
From the Organization page, navigate to the first row in the table, select
and then select Edit organization.
Enter a new organization name and select Apply.
Get the organization ID
The organization ID is used for certain integrations with BlueXP.
You can view the organization ID from the Organizations page and copy it to the clipboard for your needs.
Select the Organization tab to view the Organization page.
On the Organization page, look for your organization ID in the summary bar and copy it to the clipboard. You can save this for use later or copy it directly to where you need to use it.
Obtain the ID for a project
If you're using the BlueXP API, you might need to obtain the ID for a project. For example, when creating a Cloud Volumes ONTAP working environment.
From the Organization page, navigate to a project in the table and select
The project ID displays.
To copy the ID, select the copy button.
