BlueXP setup and administration
Monitor or audit IAM activity from the BlueXP timeline
Contributors netapp-bcammett
If you need to monitor or audit an action that was completed from BlueXP identity and access management (IAM), you can view details from the BlueXP Timeline. For example, you might want to verify who added a member to an organization or that a project was deleted successfully.
Steps
  1. In the upper right of the BlueXP console, select The settings icon which displays in the top right of the BlueXP web console. > Timeline.
  2. From the filters, select Service and then select Tenancy.
  3. Use any of the other filters to change which actions display in the table.
    For example, you can use the User filter to show actions related to a specific user account.
Result
The Timeline updates to show you completed management actions related to BlueXP IAM.
Looking for answers?
Try Doc, our Gen AI Assistant.
