Switch between BlueXP organizations, projects, and Connectors
You might belong to multiple BlueXP organizations or have permissions to access multiple projects or Connectors within a BlueXP organization. When needed, you can easily switch between organizations, projects, and Connectors to access the resources associated with that organization, project, or Connector.
You might belong to multiple organizations if you were invited to join another organization or if you created an additional organization yourself. You can create an additional organization by using the API. Learn how to create a new organization |
Switch between organizations
If you are a member of multiple organizations, you can switch between them at any time.
At the top of BlueXP, select Organization.
Select another organization and then select Switch.
BlueXP switches to the selected organization and displays the resources associated with that organization.
Switch between projects
If your organization includes multiple projects and you have access to those projects, you can switch between them at any time.
You must be on any page in the BlueXP console other than the BlueXP identity and access management (IAM) pages. You can't switch to another project when viewing any of the IAM pages.
At the top of BlueXP, select Project.
Browse through the folders and projects in your organization, select the project that you want, and then select Switch.
BlueXP switches to the selected project and displays the resources associated with that project.
Switch between Connectors
If you have multiple Connectors, you can switch between them to see the working environments that are associated with a specific Connector.
At the top of BlueXP, select Connector.
Select another Connector and then select Switch.
BlueXP refreshes and shows the working environments associated with the selected Connector.
