NetApp Console setup and administration
Organize your NetApp Console resources with folders and projects
Contributors netapp-tonias
Within the NetApp Console, you organize your NetApp resources using projects and folders. A project represents a workspace in the Console that organization members access to manage resources (for example, a Cloud Volumes ONTAP system). A folder groups related projects together. After you organize your resources into folders and projects, you can grant granular access to resources by providing organization members with permissions to specific folders and projects.
Add a folder or project
When you create your organization, it includes a single project. Add projects to manage resources and folders to group related projects together.
You can create up to seven levels of folders and projects in your organization's resource structure. Create folders within folders to build a nested structure for your organization.
Steps
  1. Select Administration > Identity and access.
  2. Select Organization.
  3. From the Organization page, select Add folder or project.
  4. Select Folder or Project.
  5. Enter folder or project details:
    • Name and location: Enter a name and choose a location in the hierarchy for the folder or project. Place a folder or project under the organization or inside another folder.
    • Resources: Select the resources that you want to associate with this folder or project.
      You can select resources associated with the parent folder or project.
    • Access: View the members who will have access to the folder or project based on the existing permissions already defined in your resource hierarchy.
      Select Add a member to assign access and a role.
  6. Select Add.
Rename a folder or project
If needed, you can change the name of your folders and projects.
Steps
  1. From the Organization page, navigate to a project or folder in the table, select An icon with three dots and then select Edit folder or Edit project.
  2. On the Edit page, enter a new name and select Apply.
Delete a folder or project
Delete folders and projects you no longer need.
Before you delete a folder or project, make sure it does not contain any resources. Learn how to remove resources.
Steps
  1. From the Organization page, navigate to a project or folder in the table, select An icon with three dots and then select Delete.
  2. Confirm that you want to delete the folder or project.
View the resources associated with a folder or project
View which resources and members are associated with a folder or project.
Steps
  1. From the Organization page, navigate to a project or folder in the table, select An icon that is three side-by-side dots and then select Edit folder or Edit project.
    A screenshot of the Organization page that shows the Edit project option when selecting the action menu for a project in the table.
  2. On the Edit page, you can view details about the selected folder or project by expanding the Resources or Access sections.
    • Select Resources to view the associated resources. In the table, the Status column identifies the resources that are associated with the folder or project.
      A screenshot of the Edit project page that shows the available resources that you can associate or disassociate with the project.
Change the resources associated with a folder or project
Members with permissions for a folder or project can access its associated resources.
Steps
  2. On the Edit page, select Resources.
  3. Select the resources that you'd like to associate or disassociate.
  4. Depending on the resources that you selected, select either Associate with the project or Disassociate from the project.
    A screenshot of the Edit project page that shows the Associate resources option that is available after you select resources that aren't currently associated.
  5. Select Apply.
View members associated with a folder or project
  • Select Access to view the members who have access to the folder or project.
    A screenshot of the Edit project page that shows the members who have access to the project.
Modify member access to a folder or project
Modify member access to control resource access.
You cannot change member access at lower levels if it is inherited from a higher hierarchy level. Update member permissions at the higher hierarchy level to change access. Alternatively, you can manage permissions from the Members page.
Steps
  2. On the Edit page, select Access to view the list of members who have access to the selected folder or project.
  3. Modify member access:
    • Add a member: Select the member that you'd like to add to the folder or project and assign them a role.
    • Change a member's role: For any members with a role other than Organization Admin, select their existing role and then choose a new role.
    • Remove member access: For members who have a role defined at the folder or project for which you're viewing, you can remove their access.
  4. Select Apply.
