BlueXP setup and administration
Changes to supported Linux operating systems
Contributors netapp-bcammett netapp-tonias
As we add and remove support for the Connector on specific Linux operating systems, you might have questions about how this support affects your existing Connector deployments.
Supported operating systems
NetApp supports the BlueXP Connector with the following Linux operating systems.
Standard mode
Manual installation
  • Ubuntu 24.04 LTS
  • Ubuntu 22.04 LTS
  • Red Hat Enterprise Linux
    • 8.6 to 8.10
    • 9.1 to 9.4
Deployment from BlueXP
Ubuntu 22.04 LTS
Deployment from the AWS Marketplace
Ubuntu 22.04 LTS
Deployment from the Azure Marketplace
Ubuntu 22.04 LTS
Restricted mode
Manual installation
  • Ubuntu 24.04 LTS
  • Ubuntu 22.04 LTS
    • 8.6 to 8.10
    • 9.1 to 9.4
Ubuntu 22.04 LTS
Ubuntu 22.04 LTS
Private mode
Manual installation
  • Ubuntu 22.04 LTS
    • 8.6 to 8.10
    • 9.1 to 9.4
Support for RHEL 8 and 9
Note the following about support for RHEL 8 and 9:
Limitations
BlueXP classification is supported if you install the Connector on a RHEL 8 or 9 host that resides on-premises. It's not supported if the RHEL 8 or 9 host resides in AWS, Azure, or Google Cloud.
Container orchestration tool
You must use the Podman tool as the container orchestration tool when installing the Connector on a RHEL 8 or 9 host. Docker Engine is not supported with RHEL 8 and 9.
Deployment mode
RHEL 8 and 9 are supported when using BlueXP in standard mode, restricted mode, and private mode.
Supported Connector versions
NetApp supports RHEL 8 and 9 beginning with the following versions of the Connector:
  • 3.9.40 when using BlueXP in standard mode or restricted mode
  • 3.9.42 when using BlueXP in private mode
New manual installations only
RHEL 8 and 9 are supported with new Connector installations when manually installing the Connector on hosts running on your premises or in the cloud.
RHEL upgrades
If you have an existing Connector running on a RHEL 7 host, we don't support upgrading the RHEL 7 operating system to RHEL 8 or 9. Learn more about existing Connectors on RHEL 7 or CentOS 7.
End of support for RHEL 7 and CentOS 7
On June 30, 2024, RHEL 7 reached end of maintenance (EOM), while CentOS 7 reached end of life (EOL). NetApp stopped supporting the Connector on these Linux distributions on June 30, 2024.
Existing Connectors on RHEL 7 or CentOS 7
If you have an existing Connector running on RHEL 7 or CentOS 7, we don't support upgrading or converting the operating system to RHEL 8 or 9. You need to create a new Connector on a supported operating system.
  1. Set up a RHEL 8 or 9 host.
  2. Install Podman.
  3. Perform a new Connector installation.
  4. Configure the Connector to discover the working environments that the old Connector was managing.
How to get started with RHEL 8 and 9
Refer to the following pages for details about host requirements, Podman requirements, and steps to install Podman and the Connector:
