Create an Azure NetApp Files working environment
After you set up a Microsoft Entra application and add the credentials to BlueXP, create an Azure NetApp Files working environment so that you can start creating the volumes that you need.
Steps
From the Canvas page, click Add Working Environment.
Select Microsoft Azure.
Next to Azure NetApp Files, select Discover.
On the Details page, enter a working environment name and select the credentials that you previously set up.
Click Continue.
Result
You should now have an Azure NetApp Files working environment.
What's next?
