Manage volumes for Azure NetApp Files
You can manage existing volumes as your storage needs change. You can edit volumes, change a volume’s service level, manage Snapshot copies, and delete volumes.
Edit a volume’s size and tags
After you create a volume, you can modify its size and tags at any time.
Open the working environment.
Hover over the volume and select Edit.
Modify the size and tags as needed.
Click Apply.
Change the volume’s service level
After you create a volume, you can change the service level at any time as long as the destination capacity pool already exists.
Hover over the volume and select Change service level.
Select the capacity pool that provides the service level that you want.
Click Change.
The volume is moved to the other capacity pool with no impact to the volume.
Manage Snapshot copies
Snapshot copies provide a point-in-time copy of your volume. Create Snapshot copies, restore the data to a new volume, and delete Snapshot copies.
Hover over the volume and choose one of the available options to manage Snapshot copies:
Create a Snapshot copy
Revert volume to Snapshot
Delete a Snapshot copy
Follow the prompts to complete the selected action.
Delete volumes
Delete the volumes that you no longer need.
Hover over the volume and click Delete.
Confirm that you want to delete the volume.
