Cloud Volumes ONTAP
Google Cloud
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Register Cloud Volumes ONTAP pay-as-you-go systems
Contributors netapp-manini
Support from NetApp is included with Cloud Volumes ONTAP pay-as-you-go (PAYGO) systems, but you must first activate support by registering the systems with NetApp.
Registering a PAYGO system with NetApp is required to upgrade ONTAP software using any of the methods described on this page.
Tip A system that isn't registered for support will still receive the software update notifications that appear in the NetApp Console when a new version is available. But you will need to register the system before you can upgrade the software.
Steps
  1. If you have not yet added your NetApp Support Site account to the Console, go to Account Settings and add it now.
  2. On the Systems page, double-click the name of the system you want to register..
  3. On the Overview tab, click the Features panel and then click the pencil icon next to Support Registration.
    400
  4. Select a NetApp Support Site account and click Register.
Result
The system is registered with NetApp.
