Cloud Volumes ONTAP
Plan your Cloud Volumes ONTAP configuration in Azure
Contributors netapp-manini netapp-ahibbard
When you deploy Cloud Volumes ONTAP in Azure, you can choose a preconfigured system that matches your workload requirements, or you can create your own configuration. If you choose your own configuration, you should understand the options available to you.
Choose a Cloud Volumes ONTAP license
Several licensing options are available for Cloud Volumes ONTAP. Each option enables you to choose a consumption model that meets your needs.
Choose a supported region
Cloud Volumes ONTAP is supported in most Microsoft Azure regions. View the full list of supported regions.
Choose a supported VM type
Cloud Volumes ONTAP supports several VM types, depending on the license type that you choose.
Understand storage limits
The raw capacity limit for a Cloud Volumes ONTAP system is tied to the license. Additional limits impact the size of aggregates and volumes. You should be aware of these limits as you plan your configuration.
Size your system in Azure
Sizing your Cloud Volumes ONTAP system can help you meet requirements for performance and capacity. You should be aware of a few key points when choosing a VM type, disk type, and disk size:
Virtual machine type
Look at the supported virtual machine types in the Cloud Volumes ONTAP Release Notes and then review details about each supported VM type. Be aware that each VM type supports a specific number of data disks.
Azure disk type with single-node systems
When you create volumes for Cloud Volumes ONTAP, you need to choose the underlying cloud storage that Cloud Volumes ONTAP uses as a disk.
Single-node systems can use these types of Azure Managed Disks:
  • Premium SSD Managed Disks provide high performance for I/O-intensive workloads at a higher cost.
  • Premium SSD v2 Managed Disks provide higher performance with lower latency at a lower cost, compared to Premium SSD Managed Disks.
  • Standard SSD Managed Disks provide consistent performance for workloads that require low IOPS.
  • Standard HDD Managed Disks are a good choice if you don't need high IOPS and want to reduce your costs.
For additional details about the use cases for these disks, refer to Microsoft Azure Documentation: What disk types are available in Azure?.
Azure disk type with HA pairs
HA systems use Premium SSD Shared Managed Disks which both provide high performance for I/O-intensive workloads at a higher cost. HA deployments created before the 9.12.1 release use Premium page blobs.
Azure disk size
When you launch Cloud Volumes ONTAP instances, you must choose the default disk size for aggregates. The NetApp Console uses this disk size for the initial aggregate, and for any additional aggregates that it creates when you use the simple provisioning option. You can create aggregates that use a disk size different from the default by using the advanced allocation option.
Tip All disks in an aggregate must be the same size.
When choosing a disk size, you should take several factors into consideration. The disk size impacts how much you pay for storage, the size of volumes that you can create in an aggregate, the total capacity available to Cloud Volumes ONTAP, and storage performance.
The performance of Azure Premium Storage is tied to the disk size. Larger disks provide higher IOPS and throughput. For example, choosing 1 TiB disks can provide better performance than 500 GiB disks, at a higher cost.
There are no performance differences between disk sizes for Standard Storage. You should choose disk size based on the capacity that you need.
Refer to Azure for IOPS and throughput by disk size:
View default system disks
In addition to the storage for user data, the Console also purchases cloud storage for Cloud Volumes ONTAP system data (boot data, root data, core data, and NVRAM). For planning purposes, it might help for you to review these details before you deploy Cloud Volumes ONTAP.
Tip The Console agent also requires a system disk. View details about the Console agent's default configuration.
Collect networking information
When you deploy Cloud Volumes ONTAP in Azure, you need to specify details about your virtual network. You can use a worksheet to collect the information from your administrator.
Azure information Your value
Region
Virtual network (VNet)
Subnet
Network security group (if using your own)
Choose a write speed
The Console enables you to choose a write speed setting for Cloud Volumes ONTAP. Before you choose a write speed, you should understand the differences between the normal and high settings and risks and recommendations when using high write speed. Learn more about write speed.
Choose a volume usage profile
ONTAP includes several storage efficiency features that can reduce the total amount of storage that you need. When you create a volume in the Console, you can choose a profile that enables these features or a profile that disables them. You should learn more about these features to help you decide which profile to use.
NetApp storage efficiency features provide the following benefits:
Thin provisioning
Presents more logical storage to hosts or users than you actually have in your physical storage pool. Instead of preallocating storage space, storage space is allocated dynamically to each volume as data is written.
Deduplication
Improves efficiency by locating identical blocks of data and replacing them with references to a single shared block. This technique reduces storage capacity requirements by eliminating redundant blocks of data that reside in the same volume.
Compression
Reduces the physical capacity required to store data by compressing data within a volume on primary, secondary, and archive storage.
