Set up licensing for Cloud Volumes ONTAP in Azure
After you decide which licensing option to use with Cloud Volumes ONTAP in Azure, you must complete a few steps before you can choose that licensing option when you create a new system.
Freemium
Select the Freemium offering to use Cloud Volumes ONTAP free of charge with up to 500 GiB of provisioned capacity. Learn more about the Freemium offering.
From the left navigation menu of the NetApp Console, select Storage > Management.
On the Systems page, select Add System and follow the steps.
On the Details and Credentials page, select Edit Credentials > Add Subscription and then follow the prompts to subscribe to the pay-as-you-go offering in the Azure Marketplace.
You won't be charged through the marketplace subscription unless you exceed 500 GiB of provisioned capacity. At that point, the system automatically converts to the Essentials package.
After you return to the Console, select Freemium when you reach the charging methods page.
Capacity-based license
Capacity-based licensing enables you to pay for Cloud Volumes ONTAP per TiB of capacity. Capacity-based licensing is available as a package: the Essentials package or the Professional package.
The Essentials and Professional packages are available with the following consumption models or purchase options:
A license purchased from NetApp (Bring-Your-Own License or BYOL)
An hourly, pay-as-you-go (PAYGO) subscription from the Azure Marketplace
An annual contract
To get started, follow the steps for the consumption model that you want to use.
BYOL
Pay upfront by purchasing a license (BYOL) from NetApp to deploy Cloud Volumes ONTAP systems in any cloud provider.
NetApp has restricted the purchase, extension, and renewal of BYOL licensing. For more information, refer to Restricted availability of BYOL licensing for Cloud Volumes ONTAP. |
Add your NetApp Support Site account to the Console
The Console automatically queries NetApp's licensing service to obtain details about the licenses associated with your NetApp Support Site account. If there are no errors, the Console automatically adds the licenses.
Your license must be available from the Console before you can use it with Cloud Volumes ONTAP. If needed, you can manually add the license to the Console.
The license that you purchased from NetApp is always charged first, but you'll be charged the hourly rate in the marketplace if you exceed your licensed capacity or if the term of your license expires.
After you return to the Console, select a capacity-based package when you reach the charging methods page.
PAYGO subscription
Pay hourly by subscribing to the offer from your cloud provider's marketplace.
When you create a Cloud Volumes ONTAP system, the Console prompts you to subscribe to the agreement that's available in the Azure Marketplace. That subscription is then associated with the system for charging. You can use that same subscription for additional systems.
From the left navigation menu, select Storage > Management.
You can manage the Azure Marketplace subscriptions associated with your Azure accounts from the Settings > Credentials page. Learn how to manage your Azure accounts and subscriptions |
Annual contract
Pay for Cloud Volumes ONTAP annually by purchasing an annual contract.
Contact your NetApp sales representative to purchase an annual contract.
The contract is available as a private offer in the Azure Marketplace.
After NetApp shares the private offer with you, you can select the annual plan when you subscribe from the Azure Marketplace during system creation.
On the Details and Credentials page, select Edit Credentials > Add Subscription > Continue.
In the Azure portal, select the annual plan that was shared with your Azure account and then select Subscribe.
Keystone Subscription
A Keystone Subscription is a pay-as-you-grow subscription-based service. Learn more about NetApp Keystone Subscriptions.
If you don't have a subscription yet, contact NetApp
Contact NetApp to authorize your user account in the Console with one or more Keystone Subscriptions.
After NetApp authorizes your account, link your subscriptions for use with Cloud Volumes ONTAP.
Select the Keystone Subscription charging method when prompted to choose a charging method.
Node-based license
A node-based license is the previous generation license for Cloud Volumes ONTAP. You could purchase a node-based license from NetApp (BYOL). Node-based licenses are available for renewal only in specific cases. For information, refer to:
