Google Cloud NetApp Volumes
Add a Google Cloud NetApp Volumes system
Contributors netapp-sineadd
After you set up a service account, add a Google Cloud NetApp Volumes system in the NetApp Console so you can view your Google Cloud NetApp Volumes instances.
Cloud volumes for this subscription are displayed in the system.
Note If you have subscriptions and volumes in multiple Google Cloud projects, you need to perform this task for each project.
Before you begin
Before adding a system for each project, make sure that:
Steps
  1. From the NetApp Console menu, select Storage and then Management.
  2. On the Systems page, select Add System and select Google Cloud Platform.
  3. Next to Google Cloud NetApp Volumes, select Discover.
  4. Provide information about your NetApp Volumes subscription:
    1. Enter the system name you want to use.
    2. From Credentials, select the Google Cloud NetApp Volumes credentials to use.
      If no credentials are listed, add Google Cloud NetApp Volumes credentials before continuing. Project and region selection are unavailable until credentials are available.
    3. From Region, select a supported region for Google Cloud NetApp Volumes.
    4. Select Discover.
Result
The Console displays your Google Cloud NetApp Volumes system.
A screenshot of Google Cloud NetApp Volumes Service system.
What's next?
View your volumes.
