Google Cloud NetApp Volumes
Quick start for Google Cloud NetApp Volumes
Contributors netapp-sineadd
Get started with Google Cloud NetApp Volumes by assigning your NetApp Console role, adding credentials, and discovering a system.
From the NetApp Console, assign the correct roles to members.
In the NetApp Console, add Google Cloud NetApp Volumes credentials.
In the NetApp Console, discover a system using the credentials, Google Cloud project, and supported region.
