Amazon S3 storage
Add S3 buckets
Contributors netapp-sineadd
When your Amazon S3 system is available in the Systems page, you can add additional buckets directly from the NetApp Console.
Steps
  1. From the Systems page, double-click the Amazon S3 system to view the Amazon S3 buckets Overview page, and click Add bucket.
    The Add bucket page is displayed.
  2. In the Add bucket page, enter the required information to create the bucket and click Apply.
    1. Enter the name you want to use for the bucket.
    2. Select the AWS account that will be the owner of the bucket. This can be the primary account where the Console agent was deployed, or it can be a different account that you have added to the NetApp Console.
    3. Select the AWS region where the bucket will be created.
    4. Optionally, you can enable S3 object locking on the bucket to store objects using a write-once-read-many (WORM) model. If you plan to use object locking, you must enable it when creating the bucket. Enabling Object Lock also enables Versioning. Learn more about object locking from the Amazon S3 documentation.
      The bucket is created.
What's next
You can't manually configure Versioning, Tags, or Encryption when initially adding a bucket. After the bucket is created you can configure these other properties of the bucket. Learn more about changing bucket settings.
