Manage users
You can view local and federated users. You can also create local users and assign them to local admin groups to determine which Grid Manager features these users can access.
Before you begin
Create a local user
You can create one or more local users and assign each user to one or more local groups. The group's permissions control which Grid Manager and Grid Management API features the user can access.
You can create local users only. Use the external identity source to manage federated users and groups.
The Grid Manager includes one predefined local user, named "root." You can't remove the root user.
Note If single sign-on (SSO) is enabled, local users can't sign in to StorageGRID.
Access the wizard
Steps
  1. Select CONFIGURATION > Access control > Admin users.
  2. Select Create user.
Enter user credentials
Steps
  1. Enter the user's full name, a unique username, and a password.
  2. Optionally, select Yes if this user should not have access to the Grid Manager or Grid Management API.
  3. Select Continue.
Assign to groups
Steps
  1. Optionally, assign the user to one or more groups to determine the user's permissions.
    If you have not yet created groups, you can save the user without selecting groups. You can add this user to a group on the Groups page.
    If a user belongs to multiple groups, the permissions are cumulative. See Manage admin groups for details.
  2. Select Create user and select Finish.
View and edit local users
You can view details for existing local and federated users. You can modify a local user to change the user's full name, password, or group membership. You can also temporarily prevent a user from accessing the Grid Manager and the Grid Management API.
You can edit local users only. Use the external identity source to manage federated users.
  • To view basic information for all local and federated users, review the table on the Users page.
  • To view all details for a specific user, edit a local user, or change a local user's password, use the Actions menu or the details page.
    Any edits are applied the next time the user signs out and then signs back in to the Grid Manager.
    Note Local users can change their own passwords using the Change password option in the Grid Manager banner.
    Task Actions menu Details page
    View user details
    1. Select the checkbox for the user.
    2. Select Actions > View user details.
    Select the user's name in the table.
    Edit full name (local users only)
    2. Select Actions > Edit full name.
    3. Enter the new name.
    4. Select Save changes.
    1. Select the user's name to display the details.
    2. Select the edit icon Edit icon.
    Deny or allow StorageGRID access
    3. Select the Access tab.
    4. Select Yes to prevent the user from signing in to the Grid Manager or the Grid Management API, or select No to allow the user to sign in.
    5. Select Save changes.
    2. Select the Access tab.
    3. Select Yes to prevent the user from signing in to the Grid Manager or the Grid Management API, or select No to allow the user to sign in.
    Change password (local users only)
    3. Select the Password tab.
    4. Enter a new password.
    5. Select Change password.
    2. Select the Password tab.
    3. Enter a new password.
    4. Select Change password.
    Change groups (local users only)
    3. Select the Groups tab.
    4. Optionally, select the link after a group name to view the group's details in a new browser tab.
    5. Select Edit groups to select different groups.
    6. Select Save changes.
    2. Select the Groups tab.
    3. Optionally, select the link after a group name to view the group's details in a new browser tab.
    4. Select Edit groups to select different groups.
Duplicate a user
You can duplicate an existing user to create a new user with the same permissions.
Steps
  2. Select Actions > Duplicate user.
  3. Complete the Duplicate user wizard.
Delete a user
You can delete a local user to permanently remove that user from the system.
Note You can't delete the root user.
Steps
  1. From the Users page, select the checkbox for each user you want to remove.
  2. Select Actions > Delete user.
  3. Select Delete user.
