MGAU: Management audit message
The Management category logs user requests to the Management API. Every HTTP request that is not a GET or HEAD request to a valid API URI logs a response containing the username, IP, and type of request to the API. Invalid API URIs (such as /api/v3-authorize) and invalid requests to valid API URIs are not logged.
Code Field Description
MDIP
Destination IP Address
The server (destination) IP address.
MDNA
Domain name
The host domain name.
MPAT
Request PATH
The request path.
MPQP
Request query parameters
The query parameters for the request.
MRBD
Request body
The content of the request body. While the response body is logged by default, the request body is logged in certain cases when the response body is empty. Because the following information is not available in the response body, it is taken from the request body for the following POST methods:
  • Username and account ID in POST authorize
  • New subnets configuration in POST /grid/grid-networks/update
  • New NTP servers in POST /grid/ntp-servers/update
  • Decommissioned server IDs in POST /grid/servers/decommission
Note: Sensitive information is either deleted (for example, an S3 access key) or masked with asterisks (for example, a password).
MRMD
Request method
The HTTP request method:
  • POST
  • PUT
  • DELETE
  • PATCH
MRSC
Response code
The response code.
MRSP
Response body
The content of the response (the response body) is logged by default.
MSIP
Source IP address
The client (source) IP address.
MUUN
User URN
The URN (uniform resource name) of the user who sent the request.
RSLT
Result
Returns successful (SUCS) or the error reported by the backend.
