Warnings for Storage Node system drive recovery
Before recovering a failed system drive of a Storage Node, review the general warnings and considerations for grid node recovery and the following specific warnings.
Storage Nodes have a Cassandra database that includes object metadata. The Cassandra database might be rebuilt in the following circumstances:
  • A Storage Node is brought back online after having been offline for more than 15 days.
  • A storage volume has failed and been recovered.
  • The system drive and one or more storage volumes fails and is recovered.
When Cassandra is rebuilt, the system uses information from other Storage Nodes. If too many Storage Nodes are offline, some Cassandra data might not be available. If Cassandra has been rebuilt recently, Cassandra data might not yet be consistent across the grid. Data loss can occur if Cassandra is rebuilt when too many Storage Nodes are offline or if two or more Storage Nodes are rebuilt within 15 days of each other.
Caution If more than one Storage Node has failed (or is offline), contact technical support. Don't perform the following recovery procedure. Data loss could occur.
Caution If this is the second Storage Node failure in less than 15 days after a Storage Node failure or recovery, contact technical support. Rebuilding Cassandra on two or more Storage Nodes within 15 days can result in data loss.
Note If more than one Storage Node at a site has failed, a site recovery procedure might be required. See How technical support recovers a site.
Caution If this Storage Node is in read-only maintenance mode to allow for the retrieval of objects by another Storage Node with failed storage volumes, recover volumes on the Storage Node with failed storage volumes before recovering this failed Storage Node. See the instructions to recover from storage volume failure where system drive is intact.
Caution If ILM rules are configured to store only one replicated copy and the copy exists on a storage volume that has failed, you will not be able to recover the object.
