Delete group
You can delete a group from the system. Any users who belong only to that group will no longer be able to sign in to the Tenant Manager or use the tenant account.
Before you begin
You are signed in to the Tenant Manager using a supported web browser.
You belong to a user group that has the Root access permission. See Tenant management permissions.
Steps
Select ACCESS MANAGEMENT > Groups.
Select the checkbox for each group you want to delete.
Select Actions > Delete group.
Select Delete group.
 PDFs
PDFs
