Duplicate group
You can create new groups more quickly by duplicating an existing group.
You are signed in to the Tenant Manager using a supported web browser.
You belong to a user group that has the Root access permission. See Tenant management permissions.
Select ACCESS MANAGEMENT > Groups.
Select the checkbox for the group you want to duplicate.
Select Duplicate group. For additional details on creating a group, see the instructions for creating groups for an S3 tenant or for a Swift tenant.
Select the Local group tab to create a local group, or select the Federated group tab to import a group from the previously configured identity source.
If single sign-on (SSO) is enabled for your StorageGRID system, users belonging to local groups will not be able to sign in to the Tenant Manager, although they can use client applications to manage the tenant's resources, based on group permissions.
Enter the group's name.
Local group: Enter both a display name and a unique name. You can edit the display name later.
Federated group: Enter the unique name. For Active Directory, the unique name is the name associated with the
sAMAccountName
attribute. For OpenLDAP, the unique name is the name associated with theuid
attribute.
Select Continue.
As needed, modify the permissions for this group.
Select Continue.
As needed, if you are duplicating a group for an S3 tenant, optionally select a different policy from the Add S3 policy radio buttons. If you selected a custom policy, update the JSON string as required.
Select Create group.
