Storage and performance requirements
You must understand the storage and performance requirements for StorageGRID nodes hosted by virtual machines, so you can provide enough space to support the initial configuration and future storage expansion.
Performance requirements
The performance of the OS volume and of the first storage volume significantly impacts the overall performance of the system. Ensure that these provide adequate disk performance in terms of latency, input/output operations per second (IOPS), and throughput.
All StorageGRID nodes require that the OS drive and all storage volumes have write-back caching enabled. The cache must be on a protected or persistent media.
Requirements for virtual machines that use NetApp ONTAP storage
If you are deploying a StorageGRID node as a virtual machine with storage assigned from a NetApp ONTAP system, you have confirmed that the volume does not have a FabricPool tiering policy enabled. For example, if a StorageGRID node is running as an virtual machine on a VMware host, ensure the volume backing the datastore for the node does not have a FabricPool tiering policy enabled. Disabling FabricPool tiering for volumes used with StorageGRID nodes simplifies troubleshooting and storage operations.
Note Never use FabricPool to tier any data related to StorageGRID back to StorageGRID itself. Tiering StorageGRID data back to StorageGRID increases troubleshooting and operational complexity.
Number of virtual machines required
Each StorageGRID site requires a minimum of three Storage Nodes.
Storage requirements by node type
In a production environment, the virtual machines for StorageGRID nodes must meet different requirements, depending on the types of nodes.
Note Disk snapshots can't be used to restore grid nodes. Instead, refer to the grid node recovery procedures for each type of node.
Node Type Storage
Admin Node
100 GB LUN for OS
200 GB LUN for Admin Node tables
200 GB LUN for Admin Node audit log
Storage Node
100 GB LUN for OS
3 LUNs for each Storage Node on this host
Note: A Storage Node can have 1 to 16 storage LUNs; at least 3 storage LUNs are recommended.
Minimum size per LUN: 4 TB
Maximum tested LUN size: 39 TB.
Storage Node (metadata-only)
100 GB LUN for OS
1 LUN
Note: Only one rangedb is required for metadata-only Storage Nodes.
Gateway Node
100 GB LUN for OS
Note Depending on the audit level configured, the size of user inputs such as S3 object key name, and how much audit log data you need to preserve, you might need to increase the size of the audit log LUN on each Admin Node.Generally, a grid generates approximately 1 KB of audit data per S3 operation, which would mean that a 200 GB LUN would support 70 million operations per day or 800 operations per second for two to three days.
Storage requirements for Storage Nodes
A software-based Storage Node can have 1 to 16 storage volumes; 3 or more storage volumes are recommended. Each storage volume should be 4 TB or larger.
Note An appliance Storage Node can also have up to 48 storage volumes.
As shown in the figure, StorageGRID reserves space for object metadata on storage volume 0 of each Storage Node. Any remaining space on storage volume 0 and any other storage volumes in the Storage Node are used exclusively for object data.
Metadata Space Storage Node
To provide redundancy and to protect object metadata from loss, StorageGRID stores three copies of the metadata for all objects in the system at each site. The three copies of object metadata are evenly distributed across all Storage Nodes at each site.
When installing a grid with metadata-only Storage Nodes, the grid must also contain a minimum number of nodes for object storage. See Types of Storage Nodes for more information about metadata-only Storage Nodes.
  • For a single-site grid, at least two Storage Nodes are configured for objects and metadata.
  • For a multi-site grid, at least one Storage Node per site are configured for objects and metadata.
When you assign space to volume 0 of a new Storage Node, you must ensure there is adequate space for that node's portion of all object metadata.
  • At a minimum, you must assign at least 4 TB to volume 0.
    Note If you use only one storage volume for a Storage Node and you assign 4 TB or less to the volume, the Storage Node might enter the storage read-only state on startup and store object metadata only.
    Note If you assign less than 500 GB to volume 0 (non-production use only), 10% of the storage volume's capacity is reserved for metadata.
  • Software-based metadata-only node resources must match the existing Storage Nodes resources. For example:
    • If the existing StorageGRID site is using SG6000 or SG6100 appliances, the software-based metadata-only nodes must meet the following minimum requirements:
      • 128 GB RAM
      • 8 core CPU
      • 8 TB SSD or equivalent storage for the Cassandra database (rangedb/0)
    • If the existing StorageGRID site is using virtual Storage Nodes with 24 GB RAM, 8 core CPU, and 3 TB or 4TB of metadata storage, the software-based metadata-only nodes should use similar resources (24 GB RAM, 8 core CPU, and 4TB of metadata storage (rangedb/0).
      When adding a new StorageGRID site, the new site total metadata capacity should, at minimum, match existing StorageGRID sites and new site resources should match the Storage Nodes at existing StorageGRID sites.
  • If you are installing a new system (StorageGRID 11.6 or higher) and each Storage Node has 128 GB or more of RAM, assign 8 TB or more to volume 0. Using a larger value for volume 0 can increase the space allowed for metadata on each Storage Node.
  • When configuring different Storage Nodes for a site, use the same setting for volume 0 if possible. If a site contains Storage Nodes of different sizes, the Storage Node with the smallest volume 0 will determine the metadata capacity of that site.
For details, go to Manage object metadata storage.
