Create service provider connections in PingFederate for OIDC in StorageGRID
Use PingFederate to create a service provider (SP) connection for each Admin Node for OpenID Connect (OIDC) in your system.
You have experience creating SP connections in PingFederate Server.
You have the Administrator's Reference Guide for PingFederate Server. The PingFederate documentation provides detailed step-by-step instructions and explanations.
You have the Admin permission for PingFederate Server.
These instructions summarize how to configure PingFederate Server version 12.1.10 as an SSO provider for StorageGRID. If you are using another version of PingFederate, you might need to adapt these instructions. Refer to the PingFederate Server documentation for detailed instructions for your release.
Use the default settings unless otherwise specified. In some cases you can use settings required by your organization, such as settings for authentication method.
Step 1: Create data store
If you haven't already, create a data store to connect PingFederate to the AD FS LDAP server.
Go to System > Data & Credentials Stores.
Select New Data Store.
For Type, select Directory (LDAP).
Select Next.
Under LDAP Configuration:
Enter the values for Hostname, User DN (username), and Password.
Use the values you used when configuring identity federation in StorageGRID.
For Active Directory, select LDAP Type.
Step 2: Create password credential validator
If you haven't already, create a password credential validator.
Select Password Credential Validators > Create New instance.
On the Type tab, enter the following information:
INSTANCE NAME and INSTANCE ID: You can use the same value for both.
Type: Select LDAP Username Password Credential Validator.
Select Next.
On the Instance Configuration tab, enter the following information:
LDAP DATASTORE: Select the data store you created.
SEARCH BASE: Enter the information for the LDAP configuration.
SEARCH FILTER: Enter sAMAccountName=${username}.
SCOPE OF SEARCH: Select Subtree.
Select Next.
On the Extended Contract tab, add the following attributes:
memberOf,objectGUID,sAMAccountName,sn, anduserPrincipalName -
Select Next > Save.
Step 3: Create IdP adapter instance
If you haven't already, create an IdP (identity provider) adapter instance.
Each Admin Node in your StorageGRID system must have an IdP connection. This ensures that users can securely sign in to and out of any Admin Node. You can create a single IdP connection for all Admin Nodes (recommended) or a different IdP connection for each Admin Node. |
Go to Authentication > Integration > IdP Adapters.
Select Create New Instance.
TYPE: Select HTML Form IdP Adapter.
Select Next.
On the IdP Adapter tab, select Add a new row to 'Credential Validators'.
Select the password credential validator you created.
Select Next.
On the Extended Contract tab, add the attributes that you mapped for the password credential validator.
Select Next.
On the Adapter Attributes tab, select the username attribute for Pseudonym.
Select Next > Next.
Review the summary and select Save.
Step 4: Configure OAuth Server and Authorization Server Settings
Configure the Authorization Server to support the grant types accepted by StorageGRID.
Go to System > Authorization Server Settings.
Verify that the following options are selected for REUSE EXISTING PERSISTENT ACCESS GRANTS FOR GRANT TYPES:
IMPLICIT
AUTHORIZATION CODE
RESOURCE OWNER PASSWORD CREDENTIALS
If your company restricts the use of RESOURCE OWNER PASSWORD CREDENTIALS, you can only use AUTHORIZATION CODE.
For OAuth Administrative Web Services Settings, select the password credential validator you created.
Step 5: Define scopes
Define the scopes in PingFederate.
Go to System > OAuth Settings > Scope Management.
On the Common Scopes tab, add the values for openid, email, and profile, if they don't already exist.
Step 6: Configure IdP Adapter Mapping
Configure IdP Adapter Mapping to map attributes from the IdP to persistent grants that are issued to clients, such as access tokens or refresh tokens.
Go to Authentication > Policy Contract Grant Mapping.
Select IdP Adapter Grant Mapping.
From the SOURCE ADAPTER INSTANCE drop-down, select the HTML Form Adapter you created.
Select Add Mapping > Contract Fulfillment.
Under Source, select Adapter for USER_KEY and USER_NAME.
Under Value, select sAMAccountName for USER_KEY and username for USER_NAME.
Select Next > Next to navigate to the summary page.
Select Save.
Step 7: Set up Resource Owner Credentials Mapping
Set up Resource Owner Credentials Mapping to ensure that user credentials are validated correctly during authentication.
Select Resource Owner Credentials Grant Mapping.
From the SOURCE PASSWORD VALIDATOR INSTANCE drop-down, select the password credential validator you created.
Add the mapping for for USER_KEY:
Under Source, select Password Credential Validator.
Under Value, select sAMAccountName.
Select Save.
Step 8: Create or import signing certificate
If you haven't already, create or import the signing certificate.
Go to Security > Signing & Decryption Keys & Certificates.
Select Create New, then enter the following information:
Common Name (CN): This should be the fully qualified domain name (FQDN) of the server.
Organization (Org): Enter the name of your organization.
Country: Provide the two-letter country code, for example, US for the United States.
Key Algorithm: Select the appropriate key algorithm, such as RSA.
Key Size: Set to 2048 bits.
Signature Algorithm: Select RSA with SHA256 as the signature algorithm to ensure secure cryptographic operations.
Step 9: Configure Access Token Management
StorageGRID uses access tokens to authenticate and authorize API requests in PingFederate.
Navigate to Applications > Access Token Management.
Type: Verify that the value is JSON Web Tokens.
Select Next.
On the Instance Configuration tab, enter the following information for Certificates:
KEY ID: Enter a unique identifier for the key.
Certificate: Add the certificate you created.
JWS ALGORITHM: Select RSA using SHA256.
ACTIVE SIGNING CERTIFICATE KEY ID: Select the KEY ID you created in this step.
Select Next > Next.
On the Access Token Attribute Contract tab, select USER_KEY for Subject Attribute Name and username for Extend the Contract.
Select Add.
Select Next > Next > Next to navigate to the summary page.
Select Save.
Step 10: Configure Access Token Mapping
Configure Access Token Mapping to use the access token you created.
Go to Applications > Access Token Mappings.
Select Access Token Mappings.
Select Add Mapping.
For Context, select Default.
For Access Token Manager, select the access token you created.
Select Next > Contract Fulfillment:
Under Source, select Persistent Grant for username.
Under Value, select USER_KEY for username.
Select Next > Save.
Step 11: Set Up the OpenID Connect Policy
Define the OpenID Connect policies for client access to the attributes that are mapped according to the OpenID specifications.
Go to Applications > OAuth Clients.
Select OpenId Connect Policy Management > Add Policy.
On the Manage Policy tab, enter the following information:
POLICY ID: A unique identifier for the policy.
POLICY NAME: A descriptive name for the policy.
ACCESS TOKEN MANAGER: Select the access token that you created.
ID TOKEN LIFETIME: Set the desired lifetime for the ID token, for example, 60 minutes or one hour.
INCLUDE USER INFO IN ID TOKEN: Select the box to include user details in the ID token.
Select Next.
On the Attribute Contract tab, remove any existing attributes that aren't required for the data store you created. Retain only the attributes that you want to pass from Ping Authentication to StorageGRID.
This is a critical step. It determines which attribute values are included in the ID token. StorageGRID inherits these values during the authentication process. -
Select Next > Next.
On the Attribute Source & User Lookup tab, select Add Attribute Source. Then enter the following information:
ATTRIBUTE SOURCE ID and ATTRIBUTE SOURCE DESCRIPTION: You can use the same value for both.
ACTIVE DATA STORE: Select the data store you created.
Select Next.
On the LDAP Directory Search tab:
Enter the Base DN, which should exactly match the value you entered in StorageGRID for the LDAP server.
From the ROOT OBJECT CLASS dropdown, select objectClass.
From the ATTRIBUTE drop-down, add an attribute for each object class that you want to map. For example:
InetOrgPerson: Add displayName, givenName, or HomePhone.
user: Add LocalID or userPrincipalName (upn).
top: Add memberOf or name.
person: Add sn.
Select Next.
On the LDAP Filter tab, enter sAMAccountName=${username}.
You need to customize the LDAP filter to ensure StorageGRID retrieves the user attributes based on your organization's specific Active Directory or LDAP structure. Consult with your LDAP/AD administrator to obtain the appropriate filter expression for your setup.
Select Save and review the summary.
On the Contract Fulfillment tab, enter the following information:
Source: Select the LDAP data store you created.
Value: Map each Attribute Contract to the respective value.
Select Next > Next.
Go to Applications > OAuth Clients > OpenID Connect Policy Management.
Verify that the policy you created is set as the default policy.
Step 12: Create OAuth Client for OAuth Server
Create a new OAuth client to configure the necessary client credentials and authorize connections between PingFederate and StorageGRID.
Select Add Client, then enter the following information:
CLIENT ID: Enter a unique value.
CLIENT AUTHENTICATION: Select Client Secret.
CLIENT SECRET: Select CHANGE SECRET > Generate Secret.
This generates the secret key for the client. Save this key for use later.
REDIRECT URIS: Provide the StorageGRID return URLs in the Redirect URI section. These URLs should match the URLs configured in StorageGRID for OAuth: For example:
https://<Admin IP or Hostname>/api/v4/oidc-callback -
https://<Admin IP or Hostname>/api/v4/oidc-logged-out -
ALLOWED GRANT TYPES: Select the following options:
Authorization Code: This initiates the OAuth flow.
Refresh Token: Obtain a new token when an access token expires.
Resource Owner Password Credentials: If you need direct access to user credentials for authentication.
OPENID CONNECT: Select RSA using SHA-256 for ID Token Signing Algorithm.
Logout Mode: Select OIDC Back-Channel.
Front-Channel Logout URI, Back-Channel Logout URI, and Post-Logout Redirect URI: Add the StorageGRID logout URI:
Select Save.
After creating SP connections, configure SSO using OIDC.
