Learn about setting up SSO in StorageGRID using SAML
Setting up single sign-on (SSO) in StorageGRID allows StorageGRID (the service provider) and the SSO identity provider to communicate securely about user authentication requests.
You can set up SSO in StorageGRID using OpenID Connect (OIDC) or SAML. Follow these high-level steps to set up SSO in StorageGRID using SAML or learn about setting up SSO using OIDC.
Configure SSOSelect the Configure SSO wizard for SAML. Then, configure SSO with your identity provider and enter sandbox mode.
Learn about configuring SSO using SAML
Configure identity providerBased on the SSO identity provider you plan to use, you can select either Active Directory or Entra ID for the identity federation LDAP service type.
For Active Directory Federation Service (AD FS), you can use the AD FS, Entra ID, or PingFederate identity provider.
For Entra ID, you can only use the Entra ID identity provider.
Use the SSO identity provider's software to configure SAML for each Admin Node in your grid.
Learn about creating an application group for each Admin Node in Active Directory
Learn about creating an application for each Admin Node in Entra ID
Learn about creating a service provider connection for each Admin Node in PingFederate
Test configurationAfter configuring SAML for each Admin Node, return to the Configure SSO wizard and test the configuration.
Learn about testing the configuration for SSO
Enable SSOEnable SSO for all StorageGRID users.
Learn about enabling SSO for StorageGRID users
